I am going to make a fresh install and do all in Configuration in PaperUI. I have a lot of MQTT - Devices which needs and outgoing mapping and therefore I have to stick to the 1.x Binding at the Moment. Can I create this Items also in PaperUI or do I have to stay with textual Items only for this binding?
Items yes, Things and channels no because those don’t exist for 1.x bindings
With oh 2.5m1 this is implemented actually.
Perfect. Thank you. I will try in the next few days.
One last question:
How can I use Outgoing value transformation? I have a Map (PIR.MAP):
1=OPEN
0=CLOSSED
What exactly do I have to write in the field Outgoing value transformation?
Why do you need an outgoing transformation to a pair. They are inbound sensors.
I am sorry, of course I have a switch, which needs: ON = 1
e.g. from the old binding:
{mqtt=">[mosquitto:/ESP_Tuerklingel/gpio/0:command:ON:1],>[mosquitto:/ESP_Tuerklingel/gpio/0:command:OFF:0]"}
Just add MAP:PIR.MAP
to the Outgoing Transformation field on the Channel Config.
Thank you very much!
