Termineo
(Rainer)
October 8, 2019, 12:35pm
1
Platform information:
Hardware: _Raspberry Pi 3
OS: openHABian 2.4.0
KNX Binding
I think I have a very beginner question - but I don’t know how to do it correct. I’m very new in programming with openHAB. I already searched in other Topics but didn’t find an answer.
My configuration has three Switch elements on the sitemap to move my rollershutters in position:
Switch item=GF_LivingRoom_ShutterLeftPosition mappings=[25="25%", 50="50%", 75="75%"]
Switch item=GF_LivingRoom_ShutterMiddlePosition mappings=[25="25%", 50="50%", 75="75%"]
Switch item=GF_LivingRoom_ShutterRightPosition mappings=[25="25%", 50="50%", 75="75%"]
The items for the three are defined e.g. like this:
Number GF_LivingRoom_ShutterRightPosition "Rolladen rechts - Höhe anfahren" <rollershutter> (GF_LivingRoom, gShutter) ["Rollershutter"] {channel=""}
That the boxes of the Switch are unchecked after every click of the button, I made this rule:
rule "Rolladen Position anfahren"
Item GF_LivingRoom_ShutterLeftPosition received update or
Item GF_LivingRoom_ShutterMiddlePosition received update or
Item GF_LivingRoom_ShutterRightPosition received update
if(GF_LivingRoom_ShutterLeftPosition.state != NULL)
GF_LivingRoom_ShutterLeft.sendCommand(GF_LivingRoom_ShutterLeftPosition.state)
GF_LivingRoom_ShutterLeftPosition.state = NULL
if(GF_LivingRoom_ShutterMiddlePosition.state != NULL)
GF_LivingRoom_ShutterMiddle.sendCommand(GF_LivingRoom_ShutterMiddlePosition.state)
GF_LivingRoom_ShutterMiddlePosition.state = NULL
if(GF_LivingRoom_ShutterRightPosition.state != NULL)
GF_LivingRoom_ShutterRight.sendCommand(GF_LivingRoom_ShutterRightPosition.state)
GF_LivingRoom_ShutterRightPosition.state = NULL
My problem now is: Everything works fine but in the sitemap I always get the percentage of the item (marked yellow):
Can somebody explain why I get the %-value and is it possible to make it invisible?
Thanks in advance.
Rainer
What does your sitemap file look like?
Termineo
(Rainer)
October 8, 2019, 12:39pm
3
Here you can se an extract of the sitemap file:
Text label="Wohnzimmer" icon="sofa" {
Frame label="Licht" icon="light" {
Slider item=GF_LivingRoom_Light
Frame label="Steckdosen" icon="poweroutlet" {
Switch item=GF_LivingRoom_Power_TVRightLeft
Switch item=GF_LivingRoom_Power_TVRightRight
Switch item=GF_LivingRoom_Power_VitrineLeftLeft
Switch item=GF_LivingRoom_Power_VitrineLeftRight
Switch item=GF_LivingRoom_Power_TVMiddleMiddle
Switch item=GF_LivingRoom_Power_TVMiddleRight
Switch item=GF_LivingRoom_Power_VitrineMiddle
Switch item=GF_LivingRoom_Power_VitrineRight
Switch item=GF_LivingRoom_Power_Fensterfront_Vit
Switch item=GF_LivingRoom_Power_Fensterf_Freis
Frame label="Rolladen" icon="rollershutter" {
//Alle Rolläden
Switch item=GF_LivingRoom_ShutterAll
//Rolladen links
//Rolladen Mitte
//Rolladen rechts
Frame label="Heizungssteuerung" icon="flow" {
Default item=GF_LivingRoom_Temperature
Default item=GF_LivingRoom_SollTemperature //minValue=4.5 maxValue=30 step=0.5
Selection item=GF_LivingRoom_SollVerschTemperature mappings=[-3="-3°C", -2.5="-2.5°C", -2="-2°C", -1.5="-1.5°C", -1="-1°C", -0.5="-0.5°C", 0="keine", 0.5="+0.5°C", 1="+1°C", 1.5="+1.5°C", 2="+2°C", 2.5="+2.5°C", 3="+3°C"]
Selection item=GF_LivingRoom_Heating mappings=[1="Komfort", 2="Standby", 3="Nacht", 4="Frostschutz"]
Default item=GF_LivingRoom_Window
Text item=GF_LivingRoom_StatusStellwert
vzorglub
(Vincent Regaud)
October 8, 2019, 12:40pm
4
Add "[]"
as the label in the sitemap element:
Switch item=GF_LivingRoom_ShutterLeftPosition "[]" mappings=[25="25%", 50="50%", 75="75%"]
Switch item=GF_LivingRoom_ShutterMiddlePosition "[]" mappings=[25="25%", 50="50%", 75="75%"]
Switch item=GF_LivingRoom_ShutterRightPosition "[]" mappings=[25="25%", 50="50%", 75="75%"]
vzorglub
(Vincent Regaud)
October 8, 2019, 12:42pm
5
Also,
Why do you do that?
For what purpose?
Termineo
(Rainer)
October 8, 2019, 12:47pm
6
Thank you for the reply.
I found no other way to uncheck the 25%, 50% and 75% buttons after clicking them.
vzorglub:
When I do that on the sitemap the console says:
14:41:29.106 [WARN ] [del.core.internal.ModelRepositoryImpl] - Configuration model "myhouse.sitemap' has errors, therefore ignoring it: [52,63]: mismatched input '"[]"' expecting '}'
[55,65]: mismatched input '"[]"' expecting '}'
[58,64]: mismatched input '"[]"' expecting '}'
[60,13]: missing EOF at 'Frame'
vzorglub
(Vincent Regaud)
October 8, 2019, 12:51pm
7
My apologies:
Switch item=GF_LivingRoom_ShutterLeftPosition label="[]" mappings=[25="25%", 50="50%", 75="75%"]
Switch item=GF_LivingRoom_ShutterMiddlePosition label="[]" mappings=[25="25%", 50="50%", 75="75%"]
Switch item=GF_LivingRoom_ShutterRightPosition label="[]" mappings=[25="25%", 50="50%", 75="75%"]
vzorglub
(Vincent Regaud)
October 8, 2019, 12:53pm
8
This would be a more correct syntax:
GF_LivingRoom_ShutterLeftPosition.postUpdate(NULL)
Why use Item type Switch
instead of type Rollershutter
Termineo
(Rainer)
October 8, 2019, 1:10pm
10
Because of historical reasons. Before I had the rule I used the KNX-Binding to move to the position directly with an own item instead of using the item.sendCommand() of the already existing rollershutter item.
But you’re right - now that I use .sendCommand() I can change it back to type ‘Rollershutter’.
Termineo
(Rainer)
October 8, 2019, 1:17pm
11
vzorglub:
My apologies:
Thank you! That worked for me. Perfect
I now only have the problem that the alignment of all objects is different:
Is it possible to harmonize them?
rossko57
(Rossko57)
October 8, 2019, 1:59pm
13
I’m surprised you get any label text at all with sitemap label="[]"
You could give the label text in the sitemap, or put the null state formatter in your Item label and take away the sitemap parameter.
vzorglub
(Vincent Regaud)
October 8, 2019, 3:04pm
14
What about defining the label in the sitemap?
Switch item=GF_LivingRoom_ShutterLeftPosition label="Rolladen links - Hohe anfahren []" mappings=[25="25%", 50="50%", 75="75%"]
Sorry I don’t have the same characters
Another thing: You don’t need to postUpdate(NULL) to the Item Instead set the Item to autoupdate=“false”
Number GF_LivingRoom_ShutterRightPosition "Rolladen rechts - Höhe anfahren" <rollershutter> (GF_LivingRoom, gShutter) ["Rollershutter"] { channel="", autoupdate="false" }
This way the Item will not change its status when sending a command.
But in fact there is no reason for this rule and the proxy items.
