Hello everybody!
I’m new to openHAB and currently trying to learn it with some ‘simple’ automations. At least so I thought.
I’m trying to power on/off my tv from the basicui page.
To power on the TV i run a script with the exec binding to perform wake on lan. To shutdown it down I use a different script, also using exec. To see if the TV is on I use the network binding. I’d like to have all this functionality combined in a single switch that updates when the TV is shutdown through an external event e.g. someone uses the standard remote, and is also able to trigger the turn on/off event itself when pressed.
I currently have two switches, one displaying the on/off state and one to manually turn it on/off.
Is there an easy way to combine the two or is this not possible at all, using different bindings/triggers on the same item.
Thanks in advance!
Moritz
