Hello
I’m having an issue where these two rules are not being triggered by switch commands. They both run perfectly when triggered by Time cron but does not trigger by switch commands.
What conditions can make this happen?
The event bus is seeing the commands
2016-04-12 12:58:39 - MC_Gstatus received command ON
2016-04-12 12:58:40 - MC_Glist received command ON
2016-04-12 12:58:41 - MC_Gstatus received command ON
2016-04-12 12:58:41 - MC_Glist received command ON
Items
String MC_Text "Minecraft Reply[%s]" (MC)
Switch MC_Gstatus "Update server status" (MC) {autoupdate="false"}
String MC_status "Server status [%s]" (MC)
Switch MC_Glist "Update players" (MC) {autoupdate="false"}
Number MC_list "Players online: [%d]" (MC)
sitemap exerpt
Frame label="MinecraftServer" {
Switch item=MC_Server mappings=[ON="Start", OFF="Stop"]
Text item=MC_Text
Text item=MC_status
} // MC Server
Frame label="WIP" {
Switch item=MC_Gstatus mappings=[ON="UPDATE"]
Switch item=MC_Glist mappings=[ON="UPDATE"]
rules.
rule "Minecraft_list"
Item MC_Glist recieved command
or
Time cron "0 34 12 ? * *" // trigger by time cron set 1 or 2 mins from now. Debugger
logInfo("MC_Server", "Glist triggered")
// do stuff ...
rule "Minecraft_status"
Item MC_Gstatus recieved command
or
Time cron "0 */15 * ? * *" // every 15 mins
logInfo("MC_Server", "Gstatus triggered")
// do stuff ...
I’ve not seen examples where the “or” is put on a separate line like that. I can’t say for sure if that is the problem but it is the only thing that stands out to me. I usually put the or at the end of the line:
I have a rule with these triggers and it seems to work just fine.
Time cron "0 0 15 ? * 2,4,6" // at 15:00, any day of month, any month, mon,wed,fri
or
Time cron "0 0 13 ? * 3,5" // at 13:00, any day of month, any month, t,th
or
Time cron "0 0 11 ? * 1,7" // at 11:00 on sat,sun
however I did try that suggestion and it didnt change anything
What happens if you use received update? The event log and what I can tell from looking at the rules says it should work. Have you loaded the rules into Designer? Maybe there is a subtle syntax error preventing it from working.
Sigh I knew I would be something like this, even after looking for such things
I copied another out of context switch command to the triggers and tested that and it worked. so after reviewing
Item MC_Server received command
or
Item MC_Glist recieved command or
Time cron "0 57 12 ? * *"
‘i’ before ‘e’ except after ‘c’ … Those are the hardest errors to find without help from something like Designer. Glad you found it! Sometimes I wonder if the permissiveness of the Rules DSL is more of a hinderance than a help. Wouldn’t that have been easier to figure out and fix if there were some parse errors in the log?
