Setup:
RPi3 running openHABian
openHAB2
My skill level is ‘novice’.
Problem:
I have a Belkin Wemo switch (first “thing” added to my HA project), which is visible in Paper UI > Configuration > Things, and is also visible at Paper UI > Control where I can successfully toggle the item ON/OFF.
On to sitemap creation, I created “house.items” and “house.sitemap” with this Wemo switch as the only item.
In Basic UI I can see the sitemap and all looks as expected, but when I actuate the switch from the sitemap the switch does not respond.
I’m looking for advice from the community on how I might solve this problem.
My house.items file contains a single entry:
Switch Den_switch “Den Switch” {channel=“wemo:socket:Socket-1_0-221739K0105C2B:state”}
My house.sitemap file is as follows:
sitemap house label=“My home Automation” {
Frame label=“Den Stuff” {
Switch item=Den_Switch label=“Den Switch”
As an aside -
I have also set up another sitemap for a UPS that makes use of the Network UPS Tools binding, and all the the items I defined are visible and displaying the expected information. What’s different here though is that all the sitemap items are “Text” and therefore displaying information only; there is no control being done within this sitemap.
Thanks.
