Hi There,
I want to run a shell script with a Variable.
executeCommandLine("./myscript.sh" +theVariable)
does not work. I guess it’s a simple thing with quotations, but can’t figure it our by myself.
Any hint is appreciated.
Thanks -Michael
Hi There,
Thanks -Michael
Google is you friend
And can you post the complete rule you are trying to use, please?
What is theVariable
Depending on the content of theVariable
, you might need to add a space after .sh
executeCommandLine("./myscript.sh " +theVariable)
the Variable is an itemState as String
var theVariable = myItem.state.ToString
the shell script is working if I pass a variable in Terminal everything runs fine
That simple space did the Trick…
Thanks!
