I’m still playing and I am learning step by step. But now I running into a problem which I cannot solve by myself.
Some Channels are working well, e.g.
{channel=“systeminfo:computer:NUC:network#networkDisplayName”}
{channel=“systeminfo:computer:NUC:cpu#uptime”} etc.
But I’m not able to get the NetworkDataSent and the NetworkDataReceived to work.
Basically I used the example from the documentation without Underscores.
system.Items
Number NetworkDataSent "Data sent" {channel="systeminfo:computer:NUC:network#dataSent"}
Number NetworkDataReceived "Data received"{channel="systeminfo:computer:NUC:network#dataReceived"}
go to PaperUI and click on Control (upper left) and look for your thing/items. Does it show values?
also what pacive says, keep an eye on the log while you save something…
Try creating Items for other channels in the Network category, especially network#ip and network#networkName to see if they match with the network interface you are using.
I already did this and it all worked. Incl network name and IpAdress, Other items like storage and uptime etc all are working. Only thing what is not working is the send and receive data and packages part
@pacive the network name I received is virbr0. If I check adapter name I receive the same value… virbr0
@opus, I don’t have an additional network card.
Underneath a screenshot from my sitemap. As you can see Package send / received and Data sent / received is not working. Other items are doing great
