Hi there,
after upgrading to Openhab 2.2 (from OH2.1 stable on Openhabian), my TCP binding generates endless messages like the following:
2017-12-25 19:08:23.287 [INFO ] [ing.tcp.AbstractSocketChannelBinding] - The channel for /192.168.2.27:9090 is now connected
2017-12-25 19:08:23.554 [INFO ] [ing.tcp.AbstractSocketChannelBinding] - The channel for /192.168.2.27:9090 is now connected
2017-12-25 19:08:23.822 [INFO ] [ing.tcp.AbstractSocketChannelBinding] - The channel for /192.168.2.27:9090 is now connected
2017-12-25 19:08:24.090 [INFO ] [ing.tcp.AbstractSocketChannelBinding] - The channel for /192.168.2.27:9090 is now connected
2017-12-25 19:08:24.358 [INFO ] [ing.tcp.AbstractSocketChannelBinding] - The channel for /192.168.2.27:9090 is now connected
2017-12-25 19:08:24.626 [INFO ] [ing.tcp.AbstractSocketChannelBinding] - The channel for /192.168.2.27:9090 is now connected
2017-12-25 19:08:24.894 [INFO ] [ing.tcp.AbstractSocketChannelBinding] - The channel for /192.168.2.27:9090 is now connected
2017-12-25 19:08:25.161 [INFO ] [ing.tcp.AbstractSocketChannelBinding] - The channel for /192.168.2.27:9090 is now connected
My TCP config (more or less default):
# all parameters can be applied to both the TCP and UDP binding unless
# specified otherwise
# Port to listen for incoming connections
#port=25001
# Cron-like string to reconnect remote ends, e.g for unstable connection or remote ends
#reconnectcron=0 0 0 * * ?
# Interval between reconnection attempts when recovering from a communication error,
# in seconds
#retryinterval=5
# Queue data whilst recovering from a connection problem (TCP only)
#queue=true
# Maximum buffer size whilst reading incoming data
#buffersize=1024
# Share connections within the Item binding configurations
#itemsharedconnections=true
# Share connections between Item binding configurations
#bindingsharedconnections=true
# Share connections between inbound and outbound connections
#directionssharedconnections=false
# Allow masks in ip:port addressing, e.g. 192.168.0.1:* etc
#addressmask=true
# Pre-amble that will be put in front of data being sent
#preamble=
# Post-amble that will be appended to data being sent
postamble=\n
# Perform all write/read (send/receive) operations in a blocking mode, e.g. the binding
# will wait for a reply from the remote end after data has been sent
#blocking=false
# timeout, in milliseconds, to wait for a reply when initiating a blocking write/read
# operation
#timeout=3000
# Update the status of Items using the response received from the remote end (if the
# remote end sends replies to commands)
#updatewithresponse=true
# Timeout - or 'refresh interval', in milliseconds, of the worker thread
#refreshinterval=250
# Timeout, in milliseconds, to wait when "Selecting" IO channels ready for communication
#selecttimeout=1000
# Used character set
charset=ASCII
And finally my item (was working flawless (at least without those logs)):
Switch Streaming_Random_Mix {tcp=">[ON:192.168.2.27:9090:'MAP(squeezebox_cli.map)']"}
Once this item is enabled, those messages get thrown all the time.
Is that anything to worry about?
EDIT:
During upgrading i chose the system default when I got the question if a config file should be replaced (N is default). After changing to the new config files everything’s fine again.
So it was a system error 40 (error resides 40cm in front of screen)
