[SOLVED] TCP/UDP binding only shows installed in "add new binding"
Good day,
i"ll try to keep it short again :slight_smile:
i have seen a youtube movie a while back about the installation of openhabian on the RPI.
I remember that guy enabled tcp/udp and then did a scan for all active IP’s on his network.
Then he created a “simple - active for so long” button on the Basic UI.
In the mean while i have (quickly) rewachted every movie in my history but can not find this back… :frowning:
When i install the tcp/udp binding nothing realy happends tbh, it does not popup under configuration - bindings.
I see it is installed when go to “add a new binding” but that is it.
if i remember correctly that guys was able to open this tcp/udp thing somewhere in the paperUI and then he could do a IP scan on his network.
Any idea what i am talking about? :slight_smile:
This is a 1.x binding so you will need to create an item in your items file.
Hey H102,
hi again and thx for your reply :slight_smile:
is there a newer version available then?
I really think he had more options via paperUI then from what i have?
What version OH are you using?
2.3.0-1
1.x is the only binding I could find. I also check for a snapshot binding but no luck. Here’s the doc’s with examples to setup and configure your item.https://www.openhab.org/addons/bindings/tcp1/#binding-configuration
You might be thinking of Network binding with discovery enabled.
Hey rossko57,
that is what i have been searching for!
Thank you very much!
Hey H102,
thanks for all the effort!
Network binding seemed to be what i was looking for.
