Ich have a new Telegesis ETRX357USB-LRS on my Openhabian, running “openHAB 2.4.0 Build #1369” ( I also tested it on a Windows system, with the same result).
The Problem: After initializing the thing is going to “Status: OFFLINE Failed to initialize ZigBee transport layer”. The serial port should be okay, at least answers come back from the stick. With Minicom I can also connect to ttyUSB0 (if i disconnect OH) and send the stick AT commands to which he responds.
After 3 days fruitless search, I hope to find help here.
here the logging:
2018-09-22 10:57:34.275 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - ZigBee network starting
2018-09-22 10:57:34.279 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Initialising ZigBee coordinator
2018-09-22 10:57:34.283 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - Adding supported cluster 1280
2018-09-22 10:57:34.285 [DEBUG] [com.zsmartsystems.zigbee.ZigBeeNode ] - ClusterMatcher starting
2018-09-22 10:57:34.288 [DEBUG] [com.zsmartsystems.zigbee.ZigBeeNode ] - ClusterMatcher adding cluster IAS_ZONE
2018-09-22 10:57:34.291 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - Adding supported cluster 25
2018-09-22 10:57:34.294 [DEBUG] [com.zsmartsystems.zigbee.ZigBeeNode ] - ClusterMatcher adding cluster OTA_UPGRADE
2018-09-22 10:57:34.301 [DEBUG] [ngle.telegesis.ZigBeeDongleTelegesis] - Telegesis dongle initialize.
2018-09-22 10:57:34.304 [DEBUG] [ding.zigbee.handler.ZigBeeSerialPort] - Connecting to serial port [/dev/ttyUSB0] at 19200 baud, flow control FLOWCONTROL_OUT_NONE.
2018-09-22 10:57:34.346 [DEBUG] [ding.zigbee.handler.ZigBeeSerialPort] - Serial port [/dev/ttyUSB0] is initialized.
2018-09-22 10:57:34.370 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TelegesisFrameHandler thread started
2018-09-22 10:57:34.384 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis queue: 1
2018-09-22 10:57:34.387 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis: TelegesisSoftwareResetCommand []
2018-09-22 10:57:34.391 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis Data:ATZ
2018-09-22 10:57:34.770 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis Data:
2018-09-22 10:57:34.795 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis Data:OK
2018-09-22 10:57:34.803 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis: TelegesisSoftwareResetCommand [status=SUCCESS]
2018-09-22 10:57:34.812 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis queue: 1
2018-09-22 10:57:34.814 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis: TelegesisSetRegisterBitCommand [register=18, bit=4, state=true, password=null]
2018-09-22 10:57:34.820 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis Data:ATS124=1
2018-09-22 10:57:34.931 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis Data:OK
2018-09-22 10:57:34.933 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis: TelegesisSetRegisterBitCommand [register=18, bit=4, state=true, password=null, status=SUCCESS]
2018-09-22 10:57:34.939 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis queue: 1
2018-09-22 10:57:34.941 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis: TelegesisSetPromptEnable1Command [configuration=8804]
2018-09-22 10:57:34.947 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis Data:ATS0E=8804
2018-09-22 10:57:35.057 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis Data:OK
2018-09-22 10:57:35.059 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis: TelegesisSetPromptEnable1Command [configuration=8804, status=SUCCESS]
2018-09-22 10:57:35.064 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis queue: 1
2018-09-22 10:57:35.067 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis: TelegesisSetMainFunctionCommand [configuration=350, password=password]
2018-09-22 10:57:35.076 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis Data:ATS0A=015E:password
2018-09-22 10:57:35.188 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis Data:OK
2018-09-22 10:57:35.189 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis: TelegesisSetMainFunctionCommand [configuration=350, password=password, status=SUCCESS]
2018-09-22 10:57:35.194 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis queue: 1
2018-09-22 10:57:35.197 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis: TelegesisSetExtendedFunctionCommand [configuration=56A9]
2018-09-22 10:57:35.201 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis Data:ATS10=56A9
2018-09-22 10:57:35.313 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis Data:OK
2018-09-22 10:57:35.316 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis: TelegesisSetExtendedFunctionCommand [configuration=56A9, status=SUCCESS]
2018-09-22 10:57:35.321 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis queue: 1
2018-09-22 10:57:35.324 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis: TelegesisSetPromptEnable2Command [configuration=6B3C]
2018-09-22 10:57:35.329 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis Data:ATS0F=6B3C
2018-09-22 10:57:35.441 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis Data:OK
2018-09-22 10:57:35.443 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis: TelegesisSetPromptEnable2Command [configuration=6B3C, status=SUCCESS]
2018-09-22 10:57:35.448 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis queue: 1
2018-09-22 10:57:35.452 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis: TelegesisDisplayProductIdentificationCommand [deviceName=null, firmwareRevision=null, ieeeAddress=null]
2018-09-22 10:57:35.456 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis Data:ATI
2018-09-22 10:57:35.596 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis Data:Telegesis ETRX357-LRS
2018-09-22 10:57:35.599 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis Data:R309C
2018-09-22 10:57:35.604 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis Data:000D6F000D949788
2018-09-22 10:57:35.609 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis Data:OK
2018-09-22 10:57:35.612 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis: TelegesisDisplayProductIdentificationCommand [deviceName=ETRX357-LRS, firmwareRevision=309C, ieeeAddress=000D6F000D949788, status=SUCCESS]
2018-09-22 10:57:35.617 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis queue: 1
2018-09-22 10:57:35.620 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis: TelegesisDisplayNetworkInformationCommand [device=null, channel=null, power=null, panId=null, epanId=null]
2018-09-22 10:57:35.624 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis Data:AT+N?
2018-09-22 10:57:35.741 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis Data:+N=NoPAN
2018-09-22 10:57:35.747 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis Data:OK
2018-09-22 10:57:35.751 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis: TelegesisDisplayNetworkInformationCommand [device=NOPAN, channel=null, power=null, panId=null, epanId=null, status=SUCCESS]
2018-09-22 10:57:35.754 [DEBUG] [nal.ZigBeeNetworkStateSerializerImpl] - Loading ZigBee network state: Start.
2018-09-22 10:57:35.755 [DEBUG] [nal.ZigBeeNetworkStateSerializerImpl] - Loading ZigBee network state: File does not exist
2018-09-22 10:57:35.759 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - 000D6F000D949788: Adding local coordinator node to network
2018-09-22 10:57:35.812 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - 000D6F000D949788: Node 0 added to the network
2018-09-22 10:57:35.814 [DEBUG] [bee.internal.ZigBeeNetworkDiscoverer] - Network discovery task starting
2018-09-22 10:57:36.753 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis queue: 1
2018-09-22 10:57:36.777 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis: TelegesisDisplayNetworkInformationCommand [device=null, channel=null, power=null, panId=null, epanId=null]
2018-09-22 10:57:36.779 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis Data:AT+N?
2018-09-22 10:57:36.897 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis Data:+N=NoPAN
2018-09-22 10:57:36.901 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis Data:OK
2018-09-22 10:57:36.902 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis: TelegesisDisplayNetworkInformationCommand [device=NOPAN, channel=null, power=null, panId=null, epanId=null, status=SUCCESS]
2018-09-22 10:57:37.904 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis queue: 1
2018-09-22 10:57:37.906 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis: TelegesisDisplayNetworkInformationCommand [device=null, channel=null, power=null, panId=null, epanId=null]
2018-09-22 10:57:37.910 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis Data:AT+N?
