- Platform information:
- Hardware: Raspberry Pi Model 3B+
- OS: Openhabian
- Java Runtime Environment: Zulu
- openHAB version: 2.4
- Issue of the topic: please be detailed explaining your issue
i can’t add a thing to my openhab configuration… the thing in question is my Phoscon-GW (192.168.178.213). somehow openhab claims it already exists … but its neither listed in the Thing section nor did i define it anyway in a .things file
I simply tested defining it in the .things file but openhab still refuses to list it in the Configutation.Things section of the Paper UI.
It is lying in my Inbox though … ready to be added … or maybe not
- Please post configurations (if applicable):
- Items configuration related to the issue
No Items defined yet … - Sitemap configuration related to the issue
None - Rules code related to the issue
None - Services configuration related to the issue
Bridge hue:bridge:00212E02F47B "Phoscon Bridge Büro" [ ipAddress="192.168.178.213"] {
this is how i tried to add it in the things file … but even when i add it, its a no show in the paper UI.
I somehow assume there is an item stuck somewhere in openhab that wasnt deleted when i deleted the bridge a few days ago.
- If logs where generated please post these here using code fences:
2019-01-06 15:46:05.338 [ERROR] [ore.internal.discovery.InboxResource] - Thing hue:bridge:00212E02F47B unable to be approved: Cannot add element, because an element with same UID (hue:bridge:00212E02F47B) already exists.
