Im completley new to OH2
I have started the official docker container and now im playing a bit around.
I would like to add own, not discoverable things, with a .things file.
I have already created some .items files and some .sitemaps files. they show up properyl with the paper ui.
I have created a new test.things file and added the following content to it:
Check your openhab.log for any errors while reading the things file.
Also make sure you are pressing the authentication button on your HUE bridge while first connecting it.
You also need items that are linked to the thing channels for stuff to show up on PaperUI control section
The manually configured things should appear on the Configuration section of PaperUI (and HABmin)
Do you mean that they should appear also if there are no items linked to them?
Because, i also dont see my manually defined things in the configuration section of the paper UI.
