- Platform information:
- Hardware: INTEL i7 (Windows) Raspberry 3 (chroot Debian under Openelec)
- OS: Windows/Debian
- openHAB version:2.2
I’m testing OpenHab 2.2 on Windows and on Debian enviroment, but in all two cases I cannot load the things.
OpenHab exposes without problems Paper UI autodetected things, but my manual things are not present.
For example in debian enviroment I have a file in “things” folder (/etc/openhab2/things) called samsungac.things and it is loaded on starting time (My log explain this) and also if I change this file with nano the log says me the changed done. I have also tried to insert wrong sintax into the file and the log expose to me the error. I think, from this considerations, that the file is in correct path and with correct syntax.
My LOG:
2018-04-13 14:31:28.425 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘home.items’
2018-04-13 14:31:28.549 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘demo.items’
2018-04-13 14:31:36.032 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘home.rules’
2018-04-13 14:31:36.930 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘demo.rules’
2018-04-13 14:31:37.156 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2018-04-13 14:31:37.897 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘demo.sitemap’
2018-04-13 14:31:37.939 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘home.sitemap’
2018-04-13 14:31:38.346 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘samsungac.things’ <<<-------- HERE LOG SAYS ME MY THINGS FILE LOADING
2018-04-13 14:31:38.384 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘demo.things’
2018-04-13 14:31:38.412 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘knx.things’
2018-04-13 14:31:40.621 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at http://192.168.1.9:8080
2018-04-13 14:31:40.635 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at https://192.168.1.9:8443
2018-04-13 14:31:42.456 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2018-04-13 14:31:42.628 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2018-04-13 14:31:43.369 [INFO ] [nx.internal.connection.KNXConnection] - Established connection to KNX bus on 192.168.1.41:3671 in mode TUNNEL.
2018-04-13 14:31:43.376 [INFO ] [.samsungac.internal.SamsungAcBinding] - No refresh interval configured, using default: 60000 ms
2018-04-13 14:31:43.399 [INFO ] [b.core.service.AbstractActiveService] - Samsung Air Conditioner service has been started
2018-04-13 14:31:43.487 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
My file contains:
Thing exec:command:samsungac [ command="/etc/openhab2/samsungac/control_samsung.sh %2$s", interval=0, autorun=false ]
My thing is never displayed in Panel UI and if I use “smarthome:things list” command in Karaf.
I have not problems with items, sitemaps and rules.
I’m on this problem from five days, and it is present also in Windows version.
Can you help me please?
thanks
Fausto
