[SOLVED] This rule worked quite well but seems to have broken
Hi All
I’m on 2.4 Stable of OH2 and this used to work well (on 2.4 Snapshot), but what occurs is the lights are not dimming any more when you press play.
I can see the log turning the motion sensor on and off to prevent the lights going on/off during the movie but the dimming is failing.
Any thoughts as to why or how I can troubleshoot? I checked the items states and they are showing as OK.
var Number percent = 0
var Timer fade_timer = null
rule "When Kodi Player changed to PLAY"
        Item myKodi_control changed
if (myKodi_control.state == PLAY){
    FibaroEye1Motion_Armed.sendCommand(OFF)   // Disable the motion sensor from turning on
    //Slowly Dim the Lights if they are on
    if (LivingRoomSw1.state == ON) {
        if (fade_timer === null) {
           percent = LivingRoomDim1.state as Number
           fade_timer = createTimer(now.plusMillis(100), [ |
                if (percent > 0) {
                    percent = percent - 2
                    if (percent < 0) percent = 0
                    LivingRoomDim1.sendCommand(percent)
                    fade_timer.reschedule(now.plusMillis(100))
                } else {
                    fade_timer = null
else {
     FibaroEye1Motion_Armed.sendCommand(ON) // Enable the motion sensor for any other state of myKodi_control
You could insert some logInfo() to find out what happens - does the rule trigger, what values are you handling?
Completely random guess, the dimmer value has become a dimensionless number type.
I had a logInfo after the
And I saw it turn the Motion sensor off…
Where else would you suggest rossko57? Thank you!
The timer is only 100ms.
Try a longer one 250ms and decrement by 5
Visually there shouldn’t be much difference
The timer worked fine though Vincent previously, this rule hasn’t changed :frowning:
Just try, why not.
And add a logInfo in the timer loop
Like so?
      logInfo("TEST","TEST")
           fade_timer = createTimer(now.plusMillis(250), [ |
                logInfo(Timer, "Timer Loop")
                  if (percent > 0) {
                    percent = percent - 5
                } else {
                    fade_timer = null
else {
We only know what you tell us. We can’t see your logs.
Obviously an important thing would be if commands are sent to to LivingRoomDim1, does that happen?
If not, then the value of percent is likely not what you expect. Find out.
I rebooted OpenHab and things started to work as expected. I’ve no idea :confused:
