I’m currently playing with timers. So I created a small ruleset for testing.
var Timer tTestlicht = null
rule "Timerdemo"
Time cron "0 0/1 * * * ? *"
if(tTestlicht !== null) {
if(tTestlicht.isRunning) logInfo("TEST", "Is running!")
else logInfo("TEST", "Is NOT running!")
if(tTestlicht.hasTerminated) logInfo("TEST", "Has terminated!")
else logInfo("TEST", "Has NOT terminated!")
} else {
logInfo("TEST", "Creating tTestlicht!")
tTestlicht = createTimer(now.plusSeconds(180)) [|
logInfo("TEST", "tTestlicht is done!")
And that’s the output of the 3 minutes running ruleset:
13:17:00.365 ... - Creating tTestlicht!
13:18:00.022 ... - Is NOT running! <-- WHY?
13:18:00.032 ... - Has NOT terminated!
13:19:00.029 ... - Is NOT running! <-- WHY?
13:19:00.038 ... - Has NOT terminated!
13:20:00.015 ... - Is NOT running! <-- WHY?
13:20:00.024 ... - Has NOT terminated!
13:20:00.370 ... - tTestlicht is done!
So my questions are:
Why is isRunning not usable without a if(tTestlicht !== null) statement? When trying this, I get this error: Error during the execution of rule 'Timerdemo': cannot invoke method public abstract boolean org.eclipse.smarthome.model.script.actions.Timer.isRunning() on null
Why is isRunning always false? That’s not what I expected when using it
I’m doing this test currently on an openHAB 2 2.2.0-1 instance (openHABian).
Yes I did, but it makes no difference; tTestlicht.hasTerminated does work BTW, it is true when the 180 seconds are done… only isRunning is always false.
I think there is a misconception of the property .isRunning The meaning is to be found here:
* Determines whether the scheduled code is currently executed.
* @return true, if the code is being executed, false otherwise
public boolean isRunning();
So this is only true if the timer expires and the scheduled code is executed at this very moment.
I guess if putting a Thread::sleep(10000) into the scheduled code, there would be a chance to get a .isRunning == true
And I’m sure this will work either:
