[SOLVED] Timezone: "now" always refers to UTC?
Took some time today to investigate the issue and traced down the root cause:
  1. My System time was set correct (thanks Rich for your hint)
  2. Also joda time “now” was referring to the correct time for my timezone (thanks Kai for the info)
Problem was that I auto-start openHAB from “rc.local”. It seems that sytem time initialization is not complete and “now” gives UTC. If I start openHAB from system prompt then “now” uses correct time-zone.
Issue closed for me now, thanks!
