oeiber
(Oliver Eiber)
1
openHAB (2.4.0 Build #1460) does not recognize, when the physical device switch was pushed.
In my old fhem envoirement I had to associate the device’s association group 1 with the controller.
But in openHAB there is no ability to configure the association group for this device type.
On cd-jackson the device is listed with association group: none
https://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/159
As you can see on https://products.z-wavealliance.org/products/1444/assoc?noFilename=True there is one association group.
Is it possible to create a association manually?
Thanks for your help!
Oliver
P.S: Same for Duewi ZW-ZS-3500 (duw064374)
5iver
(Scott Rushworth)
2
If association is missing for the device in the device database, you should add it. Instructions are on the site (and in forum).
chris
(Chris Jackson)
3
No - it will need to be added to the database.
oeiber
(Oliver Eiber)
4
Thank you, Chris!
I’m new to openhab, but I will give it a try
But at the moment cd-jackson.com seems to be down…
Regards,
Oliver
chris
(Chris Jackson)
5
Sorry - the main router went down this afternoon for a couple of hours, but is back up now (244 days since the last downtime, so not too bad ).
oeiber
(Oliver Eiber)
6
Association Group 1 for the TZ68 device was added to the database. I can confirm that state changes were now delived correctly to the controller.
