[SOLVED] Total running time
Hello Everybody
  • OpenHab 2.3.0.005 running on Synology 6.2.1
I have rules that calculates how long my air conditionning works in a day. I calculate the time between the starting hour and the finnishing hour. After that, I would like to add the difference to the previus value
val DateTimeType startVMC = vmcStart.state as DateTimeType
	val DateTimeType stopVMC = vmcStart.state as DateTimeType
	val Number workTime = Minutes::minutesBetween(new DateTime(startVMC.calendar.timeInMillis), now).getMinutes()
	vmcDuree.postUpdate(workTime)
What I would like to do is
vmcDuree = vmcDuree + workTime
but, I am not able to get the value
Thanks for your help
val Number duration = vmcDuree.state + workTime
vmcDuree.postUpdate(duration)
Thank you Vincent. Unfortunately it is not working.
In the log I have an error
Rule ‘VMC Last Stop’: An error occurred during the script execution: Could not invoke method: org.eclipse.smarthome.model.script.actions.BusEvent.postUpdate(org.eclipse.smarthome.core.items.Item,java.lang.Number) on instance: null
Add some logInfo statements after each line to see where the rule fails
The problem comes from
	val Number vmcduration = vmcDureeTot.state //This line gives me a probleme
	val Number duration = workTime + vmcduration
	vmcDureeTot.sendCommand(duration)
If I replace vmcDureeTot.state by a number (12 for exemple), everything works well
What is vmcDureeTot?
It is
String    vmcDuree "Dernière durée de fonctionnement [%s]"    <vmcduree> (gRestore)
String   vmcDureeTot  "Durée de fonctionnement [%s]"    <vmcduree> (gRestore)
Change these to Number
Unfortunately, it is still not working
My items :
String 				vmcStart	"Dernier démarrage [%1$td.%1$tm.%1$tY %1$tH:%1$tM]"	<vmcon> (gRestore)
String 				vmcStop		"Dernier arrêt [%1$td.%1$tm.%1$tY %1$tH:%1$tM]"		<vmcoff> (gRestore)
Number 				VmcDureeTot	"Durée de fonctionnement [%s]"		 <vmcduree> (gRestore)
My actual rules :
rule "Last Start"
    Item VMCslow changed to ON
	vmcStart.sendCommand(new DateTimeType)
rule "VMC Last Stop"
    Item VMCslow changed to OFF
	vmcStop.sendCommand(new DateTimeType)
	val Number vmcduration = VmcDureeTot.state
	VmcDureeTot.sendCommand(duration)
and logs :
Rule 'VMC Last Stop': An error occurred during the script execution: Could not invoke method: org.eclipse.smarthome.model.script.lib.NumberExtensions.operator_plus(java.lang.Number,java.lang.Number) on instance: null
Add some logs to see where it breaks and the values of your variables
Here the rules with Logs
rule "Last Start"
	logInfo("vmc.rules", "Start")
	logInfo("vmc.rules", "1")
	logInfo("vmc.rules", "2")
	logInfo("vmc.rules", "3")
	VmcDureeTot.sendCommand(vmcduration)
	logInfo("vmc.rules", "4")
Logs show me “2”
and after the error
I found my mistake
My “Number” VmcDureeTot was not defined. So the calculation did not Work. I had to set the value to 0 and after it works.
Thank you Vinvcent for your help
Hi Cyril,
Sorry but i didnt understand what you meant with " My “Number” VmcDureeTot was not defined." Can you explain a little bit?
Thanks Costa
I can only guess that the item VmcDureeTot was never assigned a value, so it remained in UNDEF.
