Hi
I am having an issue with TPLink switch. It is working fine but log file has an exception. It is dimmer so I think I configured something wrong or Binding has an issue. I have configured everything in files:
Things:
Thing tplinksmarthome:hs220:DCD645 “Swiatlo w salonie” @ “salon” [ deviceId=“xxxD645” ]
2019-01-19 07:38:02.200 [ERROR] [ome.core.thing.link.ThingLinkManager] - Exception occurred while informing handler: Value must be between 0 and 100
java.lang.IllegalArgumentException: Value must be between 0 and 100
at org.eclipse.smarthome.core.library.types.PercentType.validateValue(PercentType.java:58) ~[?:?]
at org.eclipse.smarthome.core.library.types.PercentType.<init>(PercentType.java:53) ~[?:?]
at org.eclipse.smarthome.core.library.types.DecimalType.as(DecimalType.java:160) ~[?:?]
at org.eclipse.smarthome.core.internal.items.ItemStateConverterImpl.convertToAcceptedState(ItemStateConverterImpl.java:58) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.profiles.ProfileCallbackImpl.sendUpdate(ProfileCallbackImpl.java:135) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.profiles.SystemDefaultProfile.onStateUpdateFromHandler(SystemDefaultProfile.java:54) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.CommunicationManager.lambda$9(CommunicationManager.java:477) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.CommunicationManager.lambda$11(CommunicationManager.java:497) ~[?:?]
at java.lang.Iterable.forEach(Iterable.java:75) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.CommunicationManager.handleCallFromHandler(CommunicationManager.java:493) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.CommunicationManager.stateUpdated(CommunicationManager.java:475) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ThingManagerImpl$1.stateUpdated(ThingManagerImpl.java:167) ~[?:?]
at org.eclipse.smarthome.core.thing.binding.BaseThingHandler.updateState(BaseThingHandler.java:287) ~[?:?]
at org.openhab.binding.tplinksmarthome.internal.handler.SmartHomeHandler.updateChannelState(SmartHomeHandler.java:218) ~[?:?]
at org.openhab.binding.tplinksmarthome.internal.handler.SmartHomeHandler.handleCommand(SmartHomeHandler.java:76) ~[?:?]
at org.eclipse.smarthome.core.thing.binding.BaseThingHandler.channelLinked(BaseThingHandler.java:233) ~[?:?]
at org.eclipse.smarthome.core.thing.link.ThingLinkManager.lambda$0(ThingLinkManager.java:300) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
When I set binding to TRACE mode it doesn’t give me more information beside I know which device is making an issue. Any ideas? Am I doing something wrong her?
I am getting the exact same issue. Running Openhab 2.4. Only difference for me is my things and items are all added in files. Not using PaperUI. If I comment out the HS220 items, The error goes away. As stated by the OP, it happens randomly but always when the server starts. So there is no value set yet.
I am at a loss as to what is causing this. As far as I can tell, my things and items are configured correctly.
As the OP also stated, nothing unusually in the events log. Only the long error in the opehab.log
Openhab.log
2019-01-22 08:21:22.501 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
at org.eclipse.smarthome.core.library.types.PercentType.(PercentType.java:53) ~[?:?]
at org.openhab.binding.tplinksmarthome.internal.handler.SmartHomeHandler.lambda$2(SmartHomeHandler.java:197) ~[?:?]
at java.util.ArrayList.forEach(ArrayList.java:1257) ~[?:?]
at java.util.Collections$UnmodifiableCollection.forEach(Collections.java:1080) ~[?:?]
at org.openhab.binding.tplinksmarthome.internal.handler.SmartHomeHandler.refreshChannels(SmartHomeHandler.java:197) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) ~[?:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) ~[?:?]
The binding in the release contains a bug. openHAB release versions only have the version with the release. If you would run openHAB snapshot version you would have the fixed version.
The eclipse market place is the only way to provide bindings installable from within paperui. So there I have put a fixed version of the binding. Hopefully this makes it a bit clearer.
So when there will be an update for OH this package will be included? I mean that’s the app flow - release1 -> bug report -> fix available in snapshot version -> fix verification -> stable develop version -> full regression -> release version -> fetch all newest release versions of components when releasing new OH?
Is there an non-issue way to switch the binding? I assume I need to uninstall previous one and put .jar to a new folder - which one?
What if I have Things setup in PaperUI not in a files? Will I loose them I have to start over?
Yes you need to uninstall the binding. This doesn’t remove things or items. You don’t need to copy a jar. Just enable the eclipse market place in paperui in onfiguration with level beta and the binding will show up in the binding list.
