- Platform information:
- Hardware: x64Intel/8GB RAM
- OS: Debian 9.8
- Java Runtime Environment: openJDK 64 BIt, 1.8.0_181
- openHAB version: 2.4
- Issue of the topic: TRADFRI_bulb_E27_WS_opal_980lm via HUE got no OFF Event
- Please post configurations (if applicable):
- Items configuration related to the issue
- Sitemap configuration related to the issue
- Rules code related to the issue
- Services configuration related to the issue
- If logs where generated please post these here using code fences:
Hey,
this weekend I got a new Ikea tradfri bulb. The bulb is connected to my hue base. I can control evertyhing fine. But if I tunr off the bulb via HUE App this event is not showing up in basicUI. On the other side if I turn the light on via hue app, the will be shwon in basic ui (within a litte time).
As this things is just having 4 channels I’m using “color_temperature” as switch.
Switch Light_switch “switch” ( gLight) [“Lighting”, “Switchable”] {channel=“hue:0220:XXXXX:X:color_temperature”}
any Ideas what is missing?
Thanks.
_David
