Hello
I took the instructions to configure an RGB strip from a post by another user. My Hardware is the following: OH 2.4, mosquitto 1.0, MagicHome Alc-01 with Tasmota firmware.
Everything works fine, except for this error when I switch ON / OFF
org.openhab.core.transform.TransformationException: Invalid path '$.Dimmer' in '{"POWER":"OFF"}'
at org.openhab.core.transform.TransformationHelper$TransformationServiceDelegate.transform(TransformationHelper.java:67) ~[196:org.openhab.core.compat1x:2.4.0]
at org.openhab.binding.mqtt.internal.MqttMessageSubscriber.processMessage(MqttMessageSubscriber.java:133) [227:org.openhab.binding.mqtt:1.13.0]
at org.openhab.io.transport.mqtt.internal.MqttBrokerConnection.messageArrived(MqttBrokerConnection.java:570) [234:org.openhab.io.transport.mqtt:1.13.0]
at org.eclipse.paho.client.mqttv3.internal.CommsCallback.deliverMessage(CommsCallback.java:475) [234:org.openhab.io.transport.mqtt:1.13.0]
at org.eclipse.paho.client.mqttv3.internal.CommsCallback.handleMessage(CommsCallback.java:379) [234:org.openhab.io.transport.mqtt:1.13.0]
at org.eclipse.paho.client.mqttv3.internal.CommsCallback.run(CommsCallback.java:183) [234:org.openhab.io.transport.mqtt:1.13.0]
at java.lang.Thread.run(Unknown Source) [?:?]
item file:
Group gRGB "lights" <light>
Color cucina_Arilux_Color "cucina RGB" (gRGB,Luci, Zona_giorno)
String cucina_Arilux_RGB "colore RGB [%s]" <colorlight> (gRGB,Luci, Zona_giorno) [ "Lighting" ] {mqtt="<[mosquitto:stat/luce_cucina/RESULT:state:JSONPATH($.Color)]"}
Switch cucina_Arilux_Power "Luce Cucina RGB [%s]" <light> (gRGB,Luci, Zona_giorno) [ "Lighting" ] {mqtt=">[mosquitto:cmnd/luce_cucina/POWER:command:*:default],<[mosquitto:stat/luce_cucina/RESULT:state:JSONPATH($.POWER)]", autoupdate="true"}
Dimmer cucina_Arilux_Dim "dimmer Cucina [%.0f %%]" <dimmablelight> (gRGB,Luci, Zona_giorno) [ "Lighting" ] {mqtt=">[mosquitto:cmnd/luce_cucina/DIMMER:command:*:default],<[mosquitto:stat/luce_cucina/RESULT:state:JSONPATH($.Dimmer)]"}
while if I act on the dimmer or on the colors it’s all ok. I searched among the various posts but I didn’t find the solution … what doesn’t work?
