i’m currently stuck on set a slider value via transformation to the device. While reading was easy, writing back sems to be not. It seems like the transformationPatternOut is not detected correctly. But i don’t see the reason for the error.
Platform information
- Hardware: Raspberry PI 4GB/ 32GB MicroSD
- OS: Openhabian
- Java Runtime Environment: 1.8u222
- openHAB version: 2.5
- Zigbee2MQTT
- Device: https://www.zigbee2mqtt.io/devices/SPZB0001.html
Thing
Thing topic eurotronicspzb03 "thermostat study" {
Channels:
Type number: local_temperature [ stateTopic="zigbee2mqtt/eurotronicspzb03", transformationPattern="JSONPATH:$.local_temperature" ]
Type number: occupied_heating_setpoint [ stateTopic="zigbee2mqtt/eurotronicspzb03", transformationPattern="JSONPATH:$.occupied_heating_setpoint" ]
Type number: unoccupied_heating_setpoint [ stateTopic="zigbee2mqtt/eurotronicspzb03", transformationPattern="JSONPATH:$.unoccupied_heating_setpoint" ]
Type number: pi_heating_demand [ stateTopic="zigbee2mqtt/eurotronicspzb03", transformationPattern="JSONPATH:$.pi_heating_demand" ]
Type number: linkquality [ stateTopic="zigbee2mqtt/eurotronicspzb03", transformationPattern="JSONPATH:$.linkquality", min=0, max=255 ]
Type number: eurotronic_error_status [ stateTopic="zigbee2mqtt/eurotronicspzb03", transformationPattern="JSONPATH:$.eurotronic_error_status" ]
Type number: battery [ stateTopic="zigbee2mqtt/eurotronicspzb03", transformationPattern="JSONPATH:$.battery", min=0, max=100 ]
Type number: current_heating_setpoint [ stateTopic="zigbee2mqtt/eurotronicspzb03", commandTopic="zigbee2mqtt/eurotronicspzb03/set", transformationPattern="JSONPATH:$.current_heating_setpoint", transformationPatternOut="JS:eurotronics-current_heating_setpoint-openhab2mqtt.js", min=18.0, max=25.0, step=0.5 ]
Type number: eurotronic_system_mode [ stateTopic="zigbee2mqtt/eurotronicspzb03", transformationPattern="JSONPATH:$.eurotronic_system_mode" ]
Type string: system_mode [ stateTopic="zigbee2mqtt/eurotronicspzb03", transformationPattern="JSONPATH:$.system_mode" ]
Item
Number:Temperature eurotronicspzb03_local_temperature { channel="mqtt:topic:Openhabian:eurotronicspzb03:local_temperature" }
Number:Temperature eurotronicspzb03_occupied_heating_setpoint { channel="mqtt:topic:Openhabian:eurotronicspzb03:occupied_heating_setpoint" }
Number:Temperature eurotronicspzb03_unoccupied_heating_setpoint { channel="mqtt:topic:Openhabian:eurotronicspzb03:unoccupied_heating_setpoint" }
Number eurotronicspzb03_pi_heating_demand { channel="mqtt:topic:Openhabian:eurotronicspzb03:pi_heating_demand" }
Number eurotronicspzb03_linkquality { channel="mqtt:topic:Openhabian:eurotronicspzb03:linkquality" }
Number eurotronicspzb03_eurotronic_error_status { channel="mqtt:topic:Openhabian:eurotronicspzb03:eurotronic_error_status" }
Number eurotronicspzb03_battery { channel="mqtt:topic:Openhabian:eurotronicspzb03:battery" }
Number:Temperature eurotronicspzb03_current_heating_setpoint { channel="mqtt:topic:Openhabian:eurotronicspzb03:current_heating_setpoint" }
Number eurotronicspzb03_eurotronic_system_mode { channel="mqtt:topic:Openhabian:eurotronicspzb03:eurotronic_system_mode" }
String eurotronicspzb03_system_mode { channel="mqtt:topic:Openhabian:eurotronicspzb03:system_mode" }
Sitemap
Text item=eurotronicspzb03_local_temperature label="Arbeitszimmer [%.1f %unit%]" icon="temperature"
Text label="Arbeitszimmer Thermostat" icon="radiator" {
Frame label="Arbeitszimmer" {
Text item=eurotronicspzb03_occupied_heating_setpoint
Text item=eurotronicspzb03_unoccupied_heating_setpoint
Text item=eurotronicspzb03_pi_heating_demand
Text item=eurotronicspzb03_linkquality
Text item=eurotronicspzb03_eurotronic_error_status
Text item=eurotronicspzb03_battery
Slider item=eurotronicspzb03_current_heating_setpoint label="Temperatur [%.1f %unit%]" icon="temperature" minValue=18 maxValue=25 step=0.5
Text item=eurotronicspzb03_eurotronic_system_mode
Text item=eurotronicspzb03_system_mode
Transformation
(function(x) {
return "{\"current_heating_setpoint\":" + x + "}";
})(input)
Log
23:21:20.255 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'eurotronicspzb03_current_heating_setpoint' received command 22.5 °C
23:21:20.264 [INFO ] [arthome.event.ItemStatePredictedEvent] - eurotronicspzb03_current_heating_setpoint predicted to become 22.5 °C
23:21:20.277 [ERROR] [rnal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.handleCommand()' on 'org.openhab.binding.mqtt.generic.internal.handler.GenericMQTTThingHandler@1765438': null
java.lang.NumberFormatException: null
at java.math.BigDecimal.<init>(BigDecimal.java:497) ~[?:1.8.0_222]
at java.math.BigDecimal.<init>(BigDecimal.java:383) ~[?:1.8.0_222]
at java.math.BigDecimal.<init>(BigDecimal.java:809) ~[?:1.8.0_222]
at org.openhab.binding.mqtt.generic.values.NumberValue.update(NumberValue.java:91) ~[?:?]
at org.openhab.binding.mqtt.generic.ChannelState.publishValue(ChannelState.java:333) ~[?:?]
at org.openhab.binding.mqtt.generic.AbstractMQTTThingHandler.handleCommand(AbstractMQTTThingHandler.java:128) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_222]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_222]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_222]
at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_222]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:152) [bundleFile:?]
at org.eclipse.smarthome.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [bundleFile:?]
at com.sun.proxy.$Proxy207.handleCommand(Unknown Source) [?:?]
at org.eclipse.smarthome.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:74) [bundleFile:?]
at org.eclipse.smarthome.core.thing.internal.profiles.SystemDefaultProfile.onCommandFromItem(SystemDefaultProfile.java:48) [bundleFile:?]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_222]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_222]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_222]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_222]
23:21:20.297 [INFO ] [smarthome.event.ItemStateChangedEvent] - eurotronicspzb03_current_heating_setpoint changed from 22.0 °C to 22.5 °C
