I’m using the HUE motion sensor for switch on/off my lights in the kitchen.
Therefore I have written the following rule, which works fine.
Number hueMotionSensorLight "Lichtstärke [%.0f]" <blinds> (gSchlafzimmer) { http="<[http://192.168.178.22/api/UV-1U1A-5Ko0/sensors/14:300000:JS(getHueLight.js)]" }
rule "Motion Sensor Kitchen ON"
Item KMotionPresence changed to ON
if(KMotionSensorLight.state <= 4){
logInfo("RULE", "Motion Sensor Kitchen ON")
LightRoofKueche.sendCommand(ON)
rule "Motion Sensor Kitchen OFF"
Item KMotionPresence changed to OFF or
Item LightRoofKueche changed to ON
if(LightRoofKueche.state == ON){
logInfo("RULE", "Motion Sensor is waiting")
Thread::sleep(60000)
if(KMotionPresence.state == OFF){
Thread::sleep(30000)
logInfo("RULE", "Motion Sensor Kitchen OFF")
LightRoofKueche.sendCommand(OFF)
I’m measuring the light level every 5 minutes, my Problem is within my rule I’m asking,
if the light level is less then 4. What I would like to do, is sending a “tigger” to the motion sensor once the light switches off, so that the light level is getting refreshed. Because in “worth case” I have to wait 5 minutes for the light before it will be switched ON again
Hope you understand what I mean
