hi everyone im Trying to expose some items having trouble
i have setup an account on myopenhab.org i have also installed the OHcloud extension & sorted the UUID and Secret and added an item too config file is this stored in the right place ?
openhab-2.1.0\conf\services\openhab.cfg
############################## openHAB Cloud Connector #############################
# The URL of the openHAB Cloud service to connect to.
# Optional, default is set to the service offered by the openHAB Foundation
# (https://myopenhab.org/)
#openhabcloud:baseURL=
# Local port that the openHAB runtime is available through HTTP.
# Optional, default is 8080
#openhabcloud:localPort=
# Defines the mode in which you want to operate the connector.
# Possible values are:
# - notification: Only push notifications are enabled, no remote access is allowed.
# - remote: Push notifications and remote access are enabled.
# Optional, default is 'remote'.
#openhabcloud:mode=
# A comma-separated list of items to be exposed to external services like IFTTT.
# Events of those items are pushed to the openHAB Cloud and commands received for
# these items from the openHAB Cloud service are accepted and sent to the local bus.
# Optional, default is an empty list.
openhabcloud:expose=Movie_Mode_Trigger,
is there anything else i need too do to expose an item because i cant see anything on the cloud habpannel,paper ui accessible from cloud
i have also tried openhabcloud:expose=Movie_Mode_Trigger at the KARAF
