I’m having trouble setting up my.openHAB on my Raspberrypi (so I can remotely access it). I was able to create a login and input my secret/UUID to my.openhab.org but now I’m getting this error:
Server error 502
I am running Java™ SE Runtime Environment (build 1.8.0-b132), Java HotSpot™ Client VM (build 25.0-b70, mixed mode) and I manually created secret key using a keygen website and plain text document.
2016-02-01 08:00:02.206 [ERROR] [.myopenhab.internal.MyOHClient] - Socket.IO error: io.socket.engineio.client.EngineIOException: websocket error 2016-02-01 08:00:21.841 [ERROR] [.myopenhab.internal.MyOHClient] - Socket.IO error: not authorized
Am doing something wrong? Did I incorrectly generated the secret key? Any help is appreciated. Thanks!
Both files are created as soon as you have the org.openhab.io.myopenhab-xxx.jar in your addons folder (and maybe openhab needs to be restarted, don’t remember exactly).
Got it working now! Thanks again for the help. I had to restart my openhab a couple times and make sure I have the myopenhab add-on installed. Then, it magically appeared with the correctly generated secret key.
