I’m trying to create a rule that will send me a notification when it’s beginning to rain but I’m having trouble getting persistence to behave the way I want. My observation is that persistence API’s behave inconsistently when trying to retrieve previousState for an item.
I am running Openhabian with OH 2.4, using mysql for persistence, and am attempting to use an item defined as:
Number:Length HomeWeatherStationInformation_CurrentPrecipitationDay "Current precipitation day [%.2f in]" (g_HomeWeatherStation_current) {channel="weatherunderground:weather:local:current#precipitationDay"}
This item is persisted on all updates, and is working properly as my graphs appear correct and manually dumping the DB table shows the updates at the timestamps as I would expect. E.g., dumping the table for part of yesterday’s data shows:
2019-02-02 00:00:00 0
2019-02-02 00:18:13 0.01
2019-02-02 00:48:14 0.03
2019-02-02 01:18:15 0.03
2019-02-02 01:48:17 0.47
2019-02-02 02:18:18 0.47
2019-02-02 02:48:20 0.26
2019-02-02 03:18:21 0.26
2019-02-02 03:48:22 0.38
2019-02-02 04:18:24 0.44
2019-02-02 04:48:26 0.5
2019-02-02 05:18:27 0.5
2019-02-02 05:48:28 0.5
2019-02-02 06:18:30 0.51
2019-02-02 06:48:31 0.51
2019-02-02 07:18:33 0.55
2019-02-02 07:48:34 0.8
2019-02-02 08:18:36 0.91
2019-02-02 08:48:38 0.98
2019-02-02 09:18:39 0.98
2019-02-02 09:48:41 1.1
2019-02-02 10:18:42 1.1
2019-02-02 10:48:43 1.1
2019-02-02 11:18:45 1.1
2019-02-02 11:48:46 1.1
2019-02-02 12:18:47 1.23
2019-02-02 12:48:49 1.23
2019-02-02 13:18:51 1.34
2019-02-02 13:37:52 1.34
2019-02-02 13:52:54 1.38
2019-02-02 14:07:55 1.39
2019-02-02 14:22:57 1.39
2019-02-02 14:37:58 1.39
2019-02-02 14:53:05 1.39
I have a rule that resets this item to zero at midnight every day, so that my other rule might be able to detect when it starts raining by catching the change from a 0 previousState to greater than 0 current state.
My rule for detecting when it starts raining looks like this:
rule "Notification when rain starts"
Item HomeWeatherStationInformation_CurrentPrecipitationDay changed
val currentRain = (HomeWeatherStationInformation_CurrentPrecipitationDay.state as QuantityType<Number>).doubleValue
val sumForToday = HomeWeatherStationInformation_CurrentPrecipitationDay.sumSince(now.withTimeAtStartOfDay)
val previousStateDef = HomeWeatherStationInformation_CurrentPrecipitationDay.previousState().state
val previousStateTrue = HomeWeatherStationInformation_CurrentPrecipitationDay.previousState(true).state
logInfo("RainNotify", "Entry. sum for today: " +
sumForToday +
", current: " +
currentRain +
", prevStateDef: " +
previousStateDef +
", prevStateTrue: " +
previousStateTrue)
if ((previousStateDef == 0) && (currentRain > 0)) {
logInfo("RainNotify", "It's beginning to rain")
notificationSenderFunc.apply("It's beginning to rain", true, true)
With this implementation, the previousStateDef and previousStateTrue values don’t seem to consistently report the value I’d expect based on the contents of the DB for this item.
For example, yesterday when setting up the logging in the rule, the first time it ran after the rule was modified I saw one entry where previousState* values show what I would expect in the log output:
2019-02-02 13:18:51.675 [INFO ] [se.smarthome.model.script.RainNotify] - Entry. sum for today: 17.05, current: 1.34 in, prevStateDef: 1.23, prevStateTrue: 1.23
Notice that the “current” value is higher than either of the prevState* values in the log message, matching the contents of the DB when comparing the log timestamp with the DB row timestamps.
However, after this log entry, all subsequent entries no longer correctly get the previousState for the item:
2019-02-02 13:52:54.496 [INFO ] [se.smarthome.model.script.RainNotify] - Entry. sum for today: 21.11, current: 1.38, prevStateDef: 1.38, prevStateTrue: 1.38
This is the first log showing the transition from 1.34 to 1.38, yet the “current” and both of the “prevState*” values show 1.38. How can this be? You can see from the DB data above that the log timestamp for 13:52:54 matches the DB entry where it transitioned from 1.34 to 1.38, so the previousState* values for the item should have been 1.34.
Am I missing something or is this a bug?
Thanks for any help or pointers anyone can provide.
Jeff
