The one you added is using a dimmer channel. Is that what you want?
Iâve imported the XML generated after I added the device. I would think this would be a âblindsâ channel not âdimmerâ, but if this is what the XML had, I have to suppose this is the right one or am I missing something?
Also, the other parameters Iâve copied from the blinds device. Should I check them somewhere?
Not an area that I have studied deeply. However, I do know that sometimes the default channel from the OH generated XML is not the best. A quick look at a few blind devices; some have âdimmerâ, but some have âblinds controlâ. Both have a percent property, but the âblinds_controlâ has a âstop/moveâ and âup/downâ property also. I donât have any of these devices, so cannot give a definitive answer, but IMO I think you could change to blinds_control without a problem. Another alternative would be to add a blinds_control channel to the multiswitch CC, but I donât know if that might mess something up. The advantage of that would be that you could try either (once the device is approved) and see what works best for you.
This seems definitely like a good aproach and then fix the one that works best!
How could I do that though?
In edit mode on that tab look for the add endpoint. Use the same command class as dimmer.
edit: oops that was from memory that must be failing. look for âNew Channelâ within the same CC
Awesome, just did it. Now itâs a matter of waiting!
I know there is a place to download the snapshot sooner instead of waiting for OH updates. Do you know where is it?
