[SOLVED] Two select items with rules do not work together
Hello everybody,
this is the first time I write in the forum but I have been using openhab for about a year, mainly to control heating lights in the home
to make the boiler work and the vacuum cleaners I created two select items, but when I select the boiler menu the aspirator no longer works, I am forced to restart the rules, but only the first one I select works, I can’t understand why in the logs I have no errors, I am attaching the code to your help
thanks
/ls
sitemaps
        Text label="Riscaldamento" icon="heating" {
	    Selection item=FF_Boiler_Modo label="Funzionamento" mappings=[0="Manuale",1="Automatico",2="Presenza",3="Pres+Aut",4="Arieggiare"]
	    Setpoint item=FF_Boiler_Heating step=1 minValue=10 maxValue=30
	    Setpoint item=FF_Boiler_minima step=1 minValue=10 maxValue=30
	    Setpoint item=FF_Boiler_massima step=1 minValue=10 maxValue=30
	    Default item=FF_Boiler_Stato label="Stato Caldaia [%s]" icon="fire"
	Text label="Aspiratori" icon="fan_ceiling" {
		Selection item=FF_Aspiratori_Modo icon="movecontrol" label="Modo" mappings=[10="Manuale",11="Automatico"]
                Setpoint item=FF_Bathroom_Imp_Hum step=1 minValue=10 maxValue=100
		Default item=FF_Bathroom_Aspiratore label="Aspiratore Bagno"
		Setpoint item=FF_Kitchen_Imp_Hum step=1 minValue=10 maxValue=100
		Default item=FF_Kitchen_Aspiratore label="Aspiratore Cucina"
rules boiler
var modo = 3
var in_casa = 1
var giorno = 1
var lavoro = 0
rule    "Modo Funzionamento"
        Item FF_Boiler_Modo received command
        switch(receivedCommand.toString) {
                case "0" : {modo=0
		logWarn("mylog","caldaia case 0")}
                case "1" : {modo=1
		logWarn("mylog","caldaia case 1")}
                case "2" : {modo=2
		logWarn("mylog","caldaia case 2")}
                case "3" : {modo=3
		logWarn("mylog","caldaia case 3")}
                case "4" : {modo=4
		logWarn("mylog","caldaia case 4")}
rule "non sono in casa"
    Item gPresence changed to OFF
	in_casa=0
rule "sono in casa"
    Item gPresence changed to ON
	in_casa=1
rule "giorno"
    Time cron "0 0 5 ? * MON,TUE,WED,THU,FRI *" or
    Time cron "0 0 7 ? * SAT,SUN"
    giorno=1
rule "notte"
    Time cron "0 0 23 ? * MON,TUE,WED,THU,SUN" or
    Time cron "0 50 23 ? * FRI,SAT"
    giorno=0
rule "lavoro"
    Time cron "0 0 8 ? * MON,TUE,WED,THU,FRI"
    lavoro=1
rule "non lavoro"
    Time cron "0 0 16 ? * MON,TUE,WED,THU,FRI *"
    lavoro=0
rule "Accendo Spengo Caldaia"
    Item FF_Boiler_Heating changed or
    Item FF_FamilyRoom_Temperature received update or
    Item FF_Boiler_Modo received command or
//manuale
	if(modo==0){
		logWarn("mylog","manuale")}
//automatico
	if(modo==1 && giorno==1 && lavoro==0){
                FF_Boiler_Heating.postUpdate(FF_Boiler_massima.state)
                logWarn("mylog","automatico1")}
	else if(modo==1 && giorno==1 && lavoro==1 || giorno==0){
                FF_Boiler_Heating.postUpdate(FF_Boiler_minima.state)
		logWarn("mylog","automatico2")}
//con presenza
	if(modo==2 && in_casa==1){
                logWarn("mylog","con presenza1")}
	else if(modo==2 && in_casa==0){
                 logWarn("mylog","con presenza2")}
//con presenza in determinati orari
	if(modo==3 && giorno==1 && in_casa==1){
                logWarn("mylog","con presenza orari1")}
	else if(modo==3 && giorno==0 && in_casa==1){
                logWarn("mylog","con presenza orari2")}
	else if(modo==3 && in_casa==0){
                logWarn("mylog","con presenza orari3")}
	if(modo==4){
		FF_Boiler_Heating.postUpdate(10)
		logWarn("mylog","imposto arieggiare a 10")}
//alla fine di tutto accendo o spengo la caldaia
    if(FF_Boiler_Heating.state > FF_FamilyRoom_Temperature.state){
		FF_Boiler_Stato.sendCommand(ON)
    else{
		FF_Boiler_Stato.sendCommand(OFF)
rules vacuum
var manuale = 0
    Item FF_Aspiratori_Modo received command
            case "10": {manuale=1
                        logWarn("mylog","aspiratore case 10")}
            case "11" : {
                    manuale=0
			logWarn("mylog","aspiratore case 11")}
rule "aspiratori automatico manuale"
Item FF_Bathroom_Humidity received update or
Item FF_Bathroom_Imp_Hum changed or
Item FF_Kitchen_Humidity received update or
Item FF_Kitchen_Imp_Hum changed
//automatico
	if(FF_Bathroom_Humidity.state > FF_Bathroom_Imp_Hum.state && manuale==0){
		FF_Bathroom_Aspiratore.sendCommand(ON)
		logWarn("mylog","automatico bagno on")
else if(FF_Bathroom_Humidity.state < FF_Bathroom_Imp_Hum.state && manuale==0){
		FF_Bathroom_Aspiratore.sendCommand(OFF)
		logWarn("mylog","automatico bagno off")
    if(FF_Kitchen_Humidity.state > FF_Kitchen_Imp_Hum.state && manuale==0){
		FF_Kitchen_Aspiratore.sendCommand(ON)
		logWarn("mylog","automatico cucina on")
else if(FF_Kitchen_Humidity.state < FF_Kitchen_Imp_Hum.state && manuale==0){
		FF_Kitchen_Aspiratore.sendCommand(OFF)
		logWarn("mylog","automatico cucina off")
//in manuale non faccio nulla
widget habpanel vacuum
    <h4>Modo</h4>
<div class="btn-group" uib-dropdown>
  <button id="single-button" type="button" class="btn btn-primary" uib-dropdown-toggle>
    {{itemValue('FF_Aspiratori_Modo') == 10 ? 'Manuale' : itemValue('FF_Aspiratori_Modo') == 11 ? 'Automatico' : ''}} <span class="caret"></span>
  </button>
  <ul class="dropdown-menu" uib-dropdown-menu role="menu" aria-labelledby="single-button">
    <li role="menuitem"><a ng-click="sendCmd('FF_Aspiratori_Modo', '10')">Manuale</a></li>
    <li class="divider"></li>
    <li role="menuitem"><a ng-click="sendCmd('FF_Aspiratori_Modo', '11')">Automatico</a></li>
  </ul>
</div>
widget habpanel boiler
<h4>Funzionamento</h4>
    {{itemValue('FF_Boiler_Modo') == 0 ? 'Manuale' : itemValue('FF_Boiler_Modo') == 1 ? 'Automatico' : itemValue('FF_Boiler_Modo') == 2 ? 'Presenza' : itemValue('FF_Boiler_Modo') == 3 ? 'Pres+Aut' : itemValue('FF_Boiler_Modo') == 4 ? 'Arieggiare' : ''}} <span class="caret"></span>
  </button>
    <li role="menuitem"><a ng-click="sendCmd('FF_Boiler_Modo', '0')">Manuale</a></li>
    <li role="menuitem"><a ng-click="sendCmd('FF_Boiler_Modo', '1')">Automatico</a></li>
    <li role="menuitem"><a ng-click="sendCmd('FF_Boiler_Modo', '2')">Presenza</a></li>
    <li role="menuitem"><a ng-click="sendCmd('FF_Boiler_Modo', '3')">Pres+Aut</a></li>
    <li role="menuitem"><a ng-click="sendCmd('FF_Boiler_Modo', '4')">Arieggiare</a></li>
  </ul>
</div>
For such selection I am using Number items and do present them as a Switch on my sitemap (instead of a Selection in your case).
What does not work? When you select one, the other can no longer be selected or selecting the other does not result in anything in the logs?
yes when I select one, the other does not change state
Personally I do not see a reason for such behavior.
At least you should consider to change your boiler rules slightly. The “main” rule for boiler uses a trigger
but in the rule you are using the var modo instead. While the var should be set from the first rule, there is no guaranty that this will take place before the main rule is triggered, so there is a chance that the wrong block is executed, even worse, there is a chance that more than one block is executed, as you are using if() instead of switch(){case{}}. This might result in strange behavior.
As you are using some global vars as boolean (but with a number), why don’t you use Boolean type?
var Boolean giorno = true
var Boolean lavoro = false
rule "giorno"
    Time cron "0 0 5 ? * MON-FRI *" or
    giorno = true
rule "notte"
    Time cron "0 0 23 ? * MON-THU,SUN" or
    giorno = false
rule "lavoro"
    Time cron "0 0 8 ? * MON-FRI"
    lavoro = true
rule "non lavoro"
    Time cron "0 0 16 ? * MON-FRI *"
    lavoro = false
    val Boolean in_casa = if(gPresence.state != ON) false else true
    if(!(FF_Boiler_Modo.state instanceof Number)) {  // in case of no valid number
        FF_Boiler_Modo.postUpdate(3)                 // set to default
        Thread::sleep(500)                           // some delay to sort things out
    switch((FF_Boiler_Modo.state as Number).intValue) {
        case 0: {                                                         //manuale
        case 1: {                                                         //automatico
            if(giorno && !lavoro) {
            } else if((giorno && lavoro) || !giorno) {
        case 2: {                                                         //con presenza
            if(in_casa){
            } else {
        case 3: {                                                         //con presenza in determinati orari
            if(!in_casa){
            } else {
                if(giorno){
                } else {
        case 4: {
    val newState = if(FF_Boiler_Heating.state > FF_FamilyRoom_Temperature.state) ON else OFF
    if(FF_Boiler_Stato.state != newState) FF_Boiler_Stato.sendCommand(newState)
thank you now it works, only one thing is wrong
in_casa = if (gPresence != ON) false else true
he does not understand if they are at home
but otherwise everything works now
gPresence is an Item?
in_casa = if (gPresence.state != ON) false else true
Jepp, sorry, forgot about the item (like @5iver already mentioned).
The extra rule for this item also isn’t necessary, so I changed the code above (moved the line to the main rule and deleted the extra rule) So the var doesn’t need to be global anymore…
