Hello!
I am hesitating now since 2 week one one issue:
I am able to send a udp message from my raspberry with OH2 via item:
Switch switch6 “Garage:” [“Lighting”] {udp=">[ON:193.172.2.40:8888:‘MAP(GARAGE.map)’], >[OFF:193.172.2.40:8888:‘MAP(GARAGE.map)’]"}
when i now write a rule and try to send:
rule “Item Roll_EG_Test1”
_ Item Roll_EG_Test1 received command_
_ logInfo(“openhab”,“Test switch 1 pressed.”)_
_ var String mymessage_
_ mymessage = “OFF”_
_ logInfo(“openhab”, “test message sent:” + mymessage)_
_ // executeCommandLine(“bash /etc/openhab2/scripts/UDPsend.sh 2d2d2d”) _
_ udp=">[ON:193.172.2.40:8888:‘MAP(TEST.map)’]" _
i will get an error message:
2018-01-01 22:13:09.330 [ome.event.ItemCommandEvent] - Item ‘Roll_EG_Test1’ received command UP
2018-01-01 22:13:09.405 [vent.ItemStateChangedEvent] - Roll_EG_Test1 changed from 100 to 0
2018-01-01 22:13:09.437 [INFO ] [lipse.smarthome.model.script.openhab] - Test switch 1 pressed.
2018-01-01 22:13:09.476 [INFO ] [lipse.smarthome.model.script.openhab] - test message sent:OFF
18-01-01 22:13:09.492 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule ‘Item Roll_EG_Test1’: An error occurred during the script execution: Couldn’t invoke ‘assignValueTo’ for feature JvmVoid: (eProxyURI: default.rules#|::0.2.0.2.0.0.0.4::0::/1)
when i comment the UDP command out i do not get this error message, please anybody who might have a clue please help me on this issue.
Best Regards,
Gregor
