I am unable to register a new user or login with my existing user account on my deployed version of Openhabcloud. I followed the instructions thoroughly as mentioned in README.md and my instance is up and running Openhabcloud at the following url.
All I am able to see is the login page, but it’s a new instance completely, no user exists currently, so how do I login ?
I am even not able to see any option to register a new user.
I have a username and password which enables me to login at the official myopenhab org , but I am unable to do so with my own instance.
Following is the screenshot of the screen I see when I try to open my openhab cloud instance.
I also tried changing in config.json
file the last line which says registration_enabled=false
, I tried setting it to true
then restarted the ngnix service, and still the option to register is not available.
Solution mentioned at one of the community links and the Issues page (#103) does not seem to work.
The Issue was also addressed at openhabcloud repository Issue no 103 and solution is mentioned the same as editing the config.json file
I edited my config.json
, then sudo service nginx restart
then sudo nohup node app.js
still facing the same issue.
Please shower some light on this.
Thank You
