[SOLVED] Unhandled exception for timer rule
  • Platform information:
    • Hardware: amd64/6gb/hp microserver n40l
    • OS: debian testing
    • Java Runtime Environment: zulu 8.31.0.1
    • openHAB version: 2.4 (from the deb repo)
  • Issue of the topic: I have a rule that turns on a circulation pump at the same time a light is turned on and turns it off after 3 minutes. It works, but gives an unhandled exception every time the rule fires and I’d like to know why. (Before you suggest using the expire binding, I tried that, but it only works when I set the expiration time to 1m, but it doesn’t work for longer periods). This is the rule:
var Timer CirculationTimer = null
rule "Cirkulacios szivattyu furdoszoba villanyra"
    Item UBathroom changed from OFF to ON
      Cirkulacios.sendCommand(ON)
      CirculationTimer = createTimer(now.plusMinutes(3)) [|
        Cirkulacios.sendCommand(OFF)
        CirkulationTimer = null
and this is the log
10:45:27.339 [INFO ] [smarthome.event.ItemCommandEvent     ] - Item 'Cirkulacios' received command OFF
10:45:27.339 [ERROR] [org.quartz.core.JobRunShell          ] - Job DEFAULT.2018-12-31T10:45:27.327+01:00: Proxy for org.eclipse.xtext.xbase.l
ib.Procedures$Procedure0: [ | {
  <XFeatureCallImplCustom>.sendCommand(<XFeatureCallImplCustom>)
  <null>.CirkulationTimer = <XNullLiteralImplCustom>
} ] threw an unhandled Exception:
java.lang.IllegalArgumentException: Couldn't invoke 'assignValueTo' for feature JvmVoid:  (eProxyURI: circulation.rules#|::0.2.0.2.0.1.7.6.1$
1.0.1::0::/1)
        at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.assignValueTo(XbaseInterpreter.java:1225) ~[?:?]
        at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:1213) ~[?:?]
        at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:216) ~[?:?]
        at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:226) ~[?:?]
        at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:204) ~[?:?]
        at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:447) ~[?:?]
        at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:228) ~[?:?]
        at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:190) ~[?:?]
        at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:46) ~[?:?]
        at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:29) ~[?:?]
        at com.sun.proxy.$Proxy145.apply(Unknown Source) ~[?:?]
        at org.eclipse.smarthome.model.script.internal.actions.TimerExecutionJob.execute(TimerExecutionJob.java:49) ~[?:?]
        at org.quartz.core.JobRunShell.run(JobRunShell.java:202) [107:org.eclipse.smarthome.core.scheduler:0.10.0.oh240]
        at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573) [107:org.eclipse.smarthome.core.scheduler:0.10.0.oh2
40]
10:45:27.340 [INFO ] [nding.souliss.internal.SoulissBinding] - receiveCommand - Cirkulacios = OFF - Typical: 0x11
10:45:27.365 [ERROR] [org.quartz.core.ErrorLogger          ] - Job (DEFAULT.2018-12-31T10:45:27.327+01:00: Proxy for org.eclipse.xtext.xbase.
lib.Procedures$Procedure0: [ | {
} ] threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception.
        at org.quartz.core.JobRunShell.run(JobRunShell.java:213) [107:org.eclipse.smarthome.core.scheduler:0.10.0.oh240]
40]
Caused by: java.lang.IllegalArgumentException: Couldn't invoke 'assignValueTo' for feature JvmVoid:  (eProxyURI: circulation.rules#|::0.2.0.2
.0.1.7.6.1.1.0.1::0::/1)
        at org.quartz.core.JobRunShell.run(JobRunShell.java:202) ~[?:?]
        ... 1 more
10:45:27.644 [INFO ] [smarthome.event.ItemStateChangedEvent] - Cirkulacios changed from ON to OFF
Try that, you don’t need the timer variable, in your case:
    createTimer(now.plusMinutes(3), [ |
Thanks, this works perfectly. I’ll spend some more time reading things, but hopefully it won’t hurt if the switch is turned off and back on again while this timer is running - it will only extend it with an additional 3 minutes right?
No, the first timer will turn off after 3 minutes
And the rule will create another timer that will turn off after 3 minutes.
For your case the rule need some work and you will need the timer variable.
I am at work now, maybe tonight
Thanks, the only important thing is that the pump turns off (I won’t mind if it’s running for 3 minutes or 6, but it should turn off eventually). Cheers :slight_smile:
Typo in your first rule
Eagle eye!
If you want the timer to reset if the light is turned on again then:
    if (CirculationTimer === null) {
        CirculationTimer = createTimer(now.plusMinutes(3), [ |
    } else {
        CirculationTimer.reschedule(now.plusMinutes(3))
Thanks Vincent! One question about the code, this curretly extends the timer to another 3 minutes when the switch is turned on while the timer is running, right? So when the timer was running for 2 minutes and the switch is turned on again, the pump will work for 5 minutes altogether (unless somebody pushes the switch again)?
Correct
