Hello all,
I’m a pure beginner for using OpenHab, and it would be really great, if anybody can help me for the following topic:
My platform is a Raspberry Pi 3 - The openHab Version is 2.4
I have a running web-Server on a Windows-PC, which controls my LCN-bus - with an own written LCN-bus communication (so I cannot use the LCN-binding)
I created a REST-Api, so the idea is to use the HTTP-binding in openHab.
As a first test I created a switch with the following entry in an item-file:
This is the sitemap:
This works!! - but:
The problem is, that I want to update the switch to the current state of the real-lamp!
The documentation says, that I have to use an “in” bounding.
To try that out I created “Teststring”, which I want to update with the result of the PHP-call.
I think I have to use “ON” and “OFF” as values, because my PHP-call delivers 0 and 1 I created a map-file:
The Problem is, that I’m getting error Messages in the “openhab.log” file:
So who can help me for the following Questions::
-Why am I getting Errors by using the Map-file even the needed entries seem to be part of the file?
- What is the correct solution to update the Switch in openHab with the correct state of the lamp?
- How can I optimize the regular updates with a Minimum of HTTP-traffic?
Thanks really a lot for your support!!
