With build 1532 the UIs seem to be available again. Although it continuously keeps logging some exceptions:
org.apache.felix.resolver.reason.ReasonException: Unable to resolve root: missing requirement ...
So far these exceptions don’t seem to impact functionality. I hope these exceptions are resolved by openhab-webui#16 when the openhab-webui build works again.
btw do you know who in the team is focused on myopenhab cloud connector? I have an issue in github and I would like to highlight somehow … just to understand if that is a bug or simply my fault.
If you have a backup that was created by using openhab-cli backup put the zipped file in var/lib/openhab2/backups then use openhab-cli restore /var/lib/openhab2/backups/whatever-backup-name.zip
If no backup then try:
sudo apt-get update
apt-cache showpkg openhab2
sudo apt-get install openhab2=2.xxxx
replacing the xxxx with the version you want to install.
I didn’t think about the backup option. Learning something new everytime I read the forums!! Luckily I copied all the all the folders over to my NAS box so I could just copy the needed folders back over to a fresh install. Then a few tweaks to get the missing links fixed. I will go the backup route as I’m starting to slowly build my sitemaps and other files.
There are several opinions on the best way to back up but for me I like to keep it simple and use openhab-cli backup or openhab-cli backup --full. The second way is a much larger file and I’ve read that it’s not needed for restoring but haven’t verified this so you may want to try both ways if going this route.
However you choose to backup OH just make sure it works by actually restoring from a backup.
