when I try to update my openhab 2.3 (running on a raspberry pi2) to 2.4 nothing work after that.
I updated via openhabian-config
My switches on the basic ui not working any more. And in the log file I get many exceptions and errors like
2018-12-21 12:05:16.605 [WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state ‘NULL’ on item ‘Season_Name’ with pattern ‘MAP(astro.map):%s’: Couldn’t transform value because transformation service of type ‘MAP’ is not available.
2018-12-21 12:05:16.852 [WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state ‘NULL’ on item ‘Day_Phase’ with pattern ‘MAP(astro.map):%s’: Couldn’t transform value because transformation service of type ‘MAP’ is not available.
2018-12-21 12:05:17.898 [WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state ‘NULL’ on item ‘Zodiac_Sign’ with pattern ‘MAP(astro.map):%s’: Couldn’t transform value because transformation service of type ‘MAP’ is not available.
2018-12-21 12:05:23.944 [WARN ] [nce.extensions.PersistenceExtensions] - There is no queryable persistence service registered with the id ‘rrd4j’
2018-12-21 12:05:23.955 [WARN ] [nce.extensions.PersistenceExtensions] - There is no queryable persistence service registered with the id ‘rrd4j’
2018-12-21 12:05:26.876 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing ‘openhab-package-demo’: Permission denied
2018-12-21 12:05:27.342 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘demo.items’
2018-12-21 12:05:27.527 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add “GroupItem” with key “gFF”. It exists already from provider “GenericItemProvider”! Failed to add a second with the same UID from provider “GenericItemProvider”!
2018-12-21 12:05:27.943 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add “GroupItem” with key “gGF”. It exists already from provider “GenericItemProvider”! Failed to add a second with the same UID from provider “GenericItemProvider”!
2018-12-21 12:05:28.032 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add “GroupItem” with key “GF_Kitchen”. It exists already from provider “GenericItemProvider”! Failed to add a second with the same UID from provider “GenericItemProvider”!
2018-12-21 12:05:28.048 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add “GroupItem” with key “GF_Corridor”. It exists already from provider “GenericItemProvider”! Failed to add a second with the same UID from provider “GenericItemProvider”!
2018-12-21 12:05:28.056 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add “GroupItem” with key “FF_Bath”. It exists already from provider “GenericItemProvider”! Failed to add a second with the same UID from provider “GenericItemProvider”!
2018-12-21 12:05:28.089 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add “GroupItem” with key “FF_Corridor”. It exists already from provider “GenericItemProvider”! Failed to add a second with the same UID from provider “GenericItemProvider”!
2018-12-21 12:05:28.455 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add “GroupItem” with key “Weather_Chart”. It exists already from provider “GenericItemProvider”! Failed to add a second with the same UID from provider “GenericItemProvider”!
2018-12-21 12:05:28.462 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add “NumberItem” with key “Weather_Temperature”. It exists already from provider “GenericItemProvider”! Failed to add a second with the same UID from provider “GenericItemProvider”!
2018-12-21 12:05:28.467 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add “NumberItem” with key “Weather_Temp_Max”. It exists already from provider “GenericItemProvider”! Failed to add a second with the same UID from provider “GenericItemProvider”!
2018-12-21 12:05:28.470 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add “NumberItem” with key “Weather_Temp_Min”. It exists already from provider “GenericItemProvider”! Failed to add a second with the same UID from provider “GenericItemProvider”!
2018-12-21 12:05:28.475 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add “NumberItem” with key “Weather_Chart_Period”. It exists already from provider “GenericItemProvider”! Failed to add a second with the same UID from provider “GenericItemProvider”!
2018-12-21 12:05:28.479 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add “DateTimeItem” with key “Weather_LastUpdate”. It exists already from provider “GenericItemProvider”! Failed to add a second with the same UID from provider “GenericItemProvider”!
2018-12-21 12:05:28.483 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add “NumberItem” with key “Sun_Elevation”. It exists already from provider “GenericItemProvider”! Failed to add a second with the same UID from provider “GenericItemProvider”!
2018-12-21 12:05:28.487 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add “NumberItem” with key “Sun_Azimuth”. It exists already from provider “GenericItemProvider”! Failed to add a second with the same UID from provider “GenericItemProvider”!
2018-12-21 12:05:28.492 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add “DateTimeItem” with key “Sunrise_Time”. It exists already from provider “GenericItemProvider”! Failed to add a second with the same UID from provider “GenericItemProvider”!
2018-12-21 12:05:28.495 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add “DateTimeItem” with key “Sunset_Time”. It exists already from provider “GenericItemProvider”! Failed to add a second with the same UID from provider “GenericItemProvider”!
2018-12-21 12:05:28.500 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add “NumberItem” with key “Moon_Elevation”. It exists already from provider “GenericItemProvider”! Failed to add a second with the same UID from provider “GenericItemProvider”!
2018-12-21 12:05:28.503 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add “NumberItem” with key “Moon_Azimuth”. It exists already from provider “GenericItemProvider”! Failed to add a second with the same UID from provider “GenericItemProvider”!
2018-12-21 12:05:28.508 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add “StringItem” with key “Moon_Phase”. It exists already from provider “GenericItemProvider”! Failed to add a second with the same UID from provider “GenericItemProvider”!
Or
2018-12-21 12:06:44.029 [ERROR] [ding.astro.handler.AstroThingHandler] - Can’t update state for channel astro:moon:local:distance#miles : org.eclipse.smarthome.binding.astro.internal.model.MoonDistance.getMiles()
java.lang.NoSuchMethodException: org.eclipse.smarthome.binding.astro.internal.model.MoonDistance.getMiles()
at java.lang.Class.getMethod(Class.java:1786) ~[?:?]
at org.eclipse.smarthome.binding.astro.internal.util.PropertyUtils.getPropertyValue(PropertyUtils.java:97) ~[?:?]
at org.eclipse.smarthome.binding.astro.internal.util.PropertyUtils.getPropertyValue(PropertyUtils.java:100) ~[?:?]
at org.eclipse.smarthome.binding.astro.internal.util.PropertyUtils.getPropertyValue(PropertyUtils.java:88) ~[?:?]
at org.eclipse.smarthome.binding.astro.internal.util.PropertyUtils.getState(PropertyUtils.java:53) ~[?:?]
at org.eclipse.smarthome.binding.astro.handler.AstroThingHandler.publishChannelIfLinked(AstroThingHandler.java:156) ~[?:?]
at org.eclipse.smarthome.binding.astro.handler.AstroThingHandler.channelLinked(AstroThingHandler.java:231) ~[?:?]
at org.eclipse.smarthome.core.thing.link.ThingLinkManager.lambda$0(ThingLinkManager.java:300) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
Or
Caused by: java.lang.IllegalStateException: ServiceLocatorImpl(__HK2_Generated_11,12,26198261) has been shut down
at org.jvnet.hk2.internal.ServiceLocatorImpl.checkState(ServiceLocatorImpl.java:2288) ~[?:?]
at org.jvnet.hk2.internal.ServiceLocatorImpl.getServiceHandleImpl(ServiceLocatorImpl.java:629) ~[?:?]
at org.jvnet.hk2.internal.ServiceLocatorImpl.getServiceHandle(ServiceLocatorImpl.java:622) ~[?:?]
at org.jvnet.hk2.internal.ServiceLocatorImpl.getServiceHandle(ServiceLocatorImpl.java:640) ~[?:?]
at org.jvnet.hk2.internal.FactoryCreator.getFactoryHandle(FactoryCreator.java:103) ~[?:?]
Any idea for that?
br
Rene
