On that last experiment, did you also make a symlink /dev/ttyAMA0 → /dev/ttyUSB0?
Just to make sure it’s not some simple oversight.
Seems like you got really close now, just a bit missing.
But yes, if you have an x86 box available that one should work for sure. All my stuff is running on x86.
ARE YOU KIDDING ME??? After all that difficult trouble shooting such a simple solution???
How could the Insteon Terminal work? That should have suffered from the same permissions problem!
Oh well, glad you got it working at last on a raspberry pi! Congrats
Yeah, I’m not sure why it worked for one and not the other, both are running as Sudo as well. But I wasn’t getting the java libraries previously, so it was probably a combination of issues.
Still Not working.
I get security is a necessary evil but I spend 25-50% of my time on fixing security issues - it’s a real productivity crusher.
Not sure this is security though…
I’m running beta oh2 from the apt repos. Just did a full fresh install to make sure that was the only issue. It wasn’t, but it was my main problem. I also had to add the openhab user to the dialout group. But, now it’s working.
Something so frustrating was so simple to fix. And such a dumb issue. I think most are just use to un-commenting a line to have it work. Lesson learned.
I hear you @tracstarr . I was in the same boat when I moved to OH2.
If you are using or planning on using a raspberry pi with openhab 2 I HIGHLY recommend using OpenHABIAN:
The author @ThomDietrich has applied so many fixes (linux security, linux USB configuration (ie. OpenHAB user added to dialout), SMB shares for remote configuration/file sharing/Designer, on and on) to the RPI install/config “gotchas” that it give you back 90% of your weekends.
I was considering throwing in the OpenHAB towel until I found OpenHABian
Thanks for pointing that out in the documentation. For myself anyway I would have never found that. There needs to be some sort of linking or tagging that can bring users there from related issues. Just my 2c.
