Hey,
I´m trying to get the sum of my persisted item-states (influxdb) with a rule.
Everything works fine when I use the item-name itself, but if I try to make this rule more generic, sumSince can´t handle the item.name stored in a variable:
*.items (for each room)
Switch WhnZ_BewegungSensor_Switch "Bewegung [MAP(motion.map):%s]" (gPresence) { channel="hue:0107:huebridge:presence_whnz:presence" }
Number WhnZ_BewegungSensor_Occupancy "Wohnzimmer [%s]" (gPresence_Timeline) { expire="2m,command=0" }
Number WhnZ_BewegungSensor_TimeCounter "Anwesenheit / heute [JS(duration.js):%s]" (gPresence_Counter)
*.rules
rule "Motion sensor triggered"
Member of gPresence received update ON
// Building item-strings
val occupancy = triggeringItem.name.split("_").get(0).toString + "_" + triggeringItem.name.split("_").get(1).toString + "_Occupancy"
val timeCounter = triggeringItem.name.split("_").get(0).toString + "_" + triggeringItem.name.split("_").get(1).toString + "_TimeCounter"
gPresence_Timeline.members.filter[ a | a.name == occupancy.toString].forEach[ a |
sendCommand(a.name, "1")
val Number onToday = a.name.sumSince(now.withTimeAtStartOfDay, "influxdb")
sendCommand(timeCounter, onToday)
error
[ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Motion sensor triggered': 'sumSince' is not a member of 'java.lang.String'; line 26, column 30, length 53
I would apreciate any hints to solve my problem.
Thank you!
