Running a RPi 4 8Gb w/ OH v3.3.0.M2 here.
I have this Samsung HVAC that was perfectly working using a small IR controller with Tasmota on it.
But I thought that besides only sending commands, I could also receive it so if I use the remote I could also get the small IR controller to receive that and OH to interpret that via MQTT.
So I already have it working using the following:
- In my thing, I set the “Incoming Value Transformations” to this: JSONPATH:$.IrReceived.IRHVAC.Power
- In my item, I set the “Profile” to JSONPATH with this: $.IrReceived.IRHVAC.Power
I can now have the item state changing automatically when I use the remote.
Problem is, since I had to change my “Custom On/Open Value” field (as well as the Off) from this: IRhvac {“Vendor”:“SAMSUNG_AC”, “Power”:“On”} to this: On, this means that I now have to use the “Outgoing Value Transformations” field, so here is where I’m stuck because I need to send a variable value (the On or Off) but since this is a HVAC, I also need to, at least, send the “Vendor” information as well.
So nesting/chaining these to work in that field, that’s where I’m stuck right now.
Any suggestions on how I can do that easily and, preferably, without having to use any rule or additional codding?
Tried this: IRhvac {“Vendor”:“SAMSUNG_AC”, “Power”: %s}, says in Tasmota: {“Command”:“Unknown”}
