Hi, I am using multiple persitance services and wanted to know if I am using them correctly in rules
The persistance services I have set up:
- influxdb… for Grafana charts
- mapdb… for restore on startup of important switches
- rrd4j… for computing average values of some items eg pressure sensor
In PaperUI System>Persistance default service I have mapdb set.
They all seem to be working except for an error in a rule where I have specified the service to use. I did it like this
AveragePressureChange.postUpdate(PressureChange.averageSince(now.minusMinutes(30),"rrd4j"))
Visual Studio code shows an error:
Ambiguous feature call.
The extension methods
postUpdate(Item, State) in BusEvent and
postUpdate(Item, Number) in BusEvent
both match.
Is the above line of code the correct way to specify the persistance service to be used?
Also, the default service is set to be mapdb. In what situations is this setting used? It seems I needed it for mapdb and rrd4j in order for one of them to work. The one not set there then has to be specified in the code as above. Influx seems quite happy without being specified anywhere.
Thanks Mark.
