# \[SOLVED\] Using OwnTracks without mqttitude binding
**URL:** <https://community.openhab.org/t/solved-using-owntracks-without-mqttitude-binding/76274>\
**Category:** Bindings\
**Tags:** owntracks, mqtt2\
**Created:** [June 13, 2019, 10:54am UTC](https://community.openhab.org/t/solved-using-owntracks-without-mqttitude-binding/76274 "2019-06-13T10:54:18Z")\
**Posts on this page:** 1\
**Showing post:** 2
<div class="post-metadata">
**Author:** ![wborn](https://community.openhab.org/user_avatar/community.openhab.org/wborn/32/55946_2.png) [@wborn](https://community.openhab.org/u/wborn)\
**Post date:** [June 13, 2019, 11:10am UTC](https://community.openhab.org/t/solved-using-owntracks-without-mqttitude-binding/76274/2 "2019-06-13T11:10:13Z")
</div>
It has been deprecated in favor of the GPS Tracker Binding, see also:
> **[GPSTracker - Bindings](https://www.openhab.org/addons/bindings/gpstracker/)**
> This binding allows you to connect mobile GPS tracker applications to openHAB and process GPS location reports.
> [@GPSTracker with Life360, OwnTracks and GPSLogger integration](https://community.openhab.org/t/gpstracker-with-owntracks-and-gpslogger-integration/49504):
> Hi, I would like to introduce my new binding that integrates OwnTracks and/or GPSLogger mobile applications directly over HTTP to provide geofencing/presence detection. I’ve been testing it on my setup for some time without any problems but it would be good to here your feedback. The pull request can be found [here](https://github.com/openhab/openhab2-addons/pull/3839), the binary can be downloaded from [here](https://openhab.jfrog.io/openhab/libs-pullrequest-local/org/openhab/binding/org.openhab.binding.gpstracker/2.4.0-SNAPSHOT/org.openhab.binding.gpstracker-2.4.0-SNAPSHOT.jar) and this is the [documentation](https://github.com/gbicskei/openhab2-addons/blob/geofence/addons/binding/org.openhab.binding.gpstracker/README.md) for setup. Cheers, Gabor
_[View the full topic](https://community.openhab.org/t/solved-using-owntracks-without-mqttitude-binding/76274)._
