I used the standard temperature icon and added some dynamic ones into openHAB-conf\icons\classic
temperature-24
temperature-15
temperature-0
But the icon in the sitemap not changing…what is wrong?
temperature-24
temperature-15
temperature-0
I do not think you can have an iconset distributed over both standard and custom libraries.
You’d need to make a complete new set using a new base filename in your custom folder.
you are correct…
Maybe some improvment point?
Why? What would be the advantage in maintaining an iconset that is a mish-mash of standard and custom parts?
It’s a pro and con for both sides so it’s up to you
Not up to me at all, but if you want something to change you generally need to sell it as “a good idea because …”
