something is changing permissions into /var/lib/openhab2 befween reboots
openhabian@openhab:~ $ openhab-cli info
Version: 2.4.0 (Build)
User: openhab (Active Process 589)
User Groups: openhab tty dialout audio bluetooth gpio
Directories: Folder Name | Path | User:Group
OPENHAB_HOME | /usr/share/openhab2 | openhab:openhab
OPENHAB_RUNTIME | /usr/share/openhab2/runtime | openhab:openhab
OPENHAB_USERDATA | /var/lib/openhab2 | openhab:openhab
OPENHAB_CONF | /etc/openhab2 | openhab:openhab
OPENHAB_LOGDIR | /var/log/openhab2 | openhab:openhab
URLs: http://10.10.1.5:8080
https://10.10.1.5:8443
openhabian@openhab:~ $ hostnamectl
Static hostname: openhab
Icon name: computer
Machine ID: 97be99ca7d444a6e947e00caf4b3e3f9
Boot ID: 2c5f9cea647740869b96d7715c2ec676
Operating System: Raspbian GNU/Linux 10 (buster)
Kernel: Linux 4.19.58-v7+
Architecture: arm
openhabian@openhab:~ $ sudo reboot
Connection to 10.10.1.5 closed by remote host.
Connection to 10.10.1.5 closed.
kriznik@GMNG:~$ tv
Linux openhab 4.19.58-v7+ #1245 SMP Fri Jul 12 17:25:51 BST 2019 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Fri Aug 9 20:39:40 2019 from 10.10.1.100
User: openhab (Active Process 590)
OPENHAB_USERDATA | /var/lib/openhab2 | root:root
edit: hmm it just looks like whole /var/lib/openhab2 is whiped out when reboot, so new folder is created empty by root after restart
because my test backup I’ve made on 2.5M2 after force reinstall is gone
If you enabled zram then /var/lib/openhab2 is in RAM.
You must properly shutdown your box in order for its contents to get synced to disk.
service zram-config stop
umount /var/lib/oepnhab2
(both of which should be executed if you properly shutdown instead of blindly typing “reboot”).
well reboot is standard server command which should not corrupt installed apps.
and which is executing proper restart sequence.
what if there will be power outage? which I believe time to time just happends and not always will UPS hold long enough. Then there will be corrupted /var/lib/openhab2 too?
… so what’s correct way then, when system command which reboots system is not the one?
for another round of science I’ve done another reinstall, verified that everything is 2.5M2
then i’ve stopped zram with sudo service zram-config stop
unfortunately there was nothing to umount as /var/lib/openhab2 was not mountpoint anywhere
and then rebooted
and after logging back 2.4 again
I know I’m just blindly rebooting system, but I would like to know how this should be done then
I’m inclined to agree with @kriznik here, a command shutdown or reboot (which will stop these services) should absolutely not cause loss or reset of data.
It’s the same binary yes but behavior depends on how it’s called. It’s confusing I know. But just type in those two commands and you should notice the difference (shutdown -r will wait for a minute).
how exactly? did you check if files were there and zram really was gone ?
I’m certainly sure that this is not the issue
but for another science I’ve done what you recommended:
Version: 2.5.0.M2 (Build)
User: openhab (Active Process 3288)
openhabian@openhab:~ $ sudo shutdown -r
Shutdown scheduled for Sat 2019-08-10 10:42:43 CEST, use 'shutdown -c' to cancel.
openhabian@openhab:~ $ Connection to 10.10.1.5 closed by remote host.
kriznik@GMNG:~$ tv
User: openhab (Active Process 588)
Yes, I‘ve enabled ZRAM (why? ). Rebooting was done with reboot command from ssh. Also toggling the power(I know that this is bad) caused same effect.
BTW might be worth adding correct reboot command to dashboard, like many routers are doing? It was first thing I looked in configuration page and found nothing.
Good because that’s what I’m worried about. Just tested on my own box with a fresh install from image and it works as designed (BTW even with “reboot” but that does not mean you should use it).
See above. You mustn’t use “reboot” or even pull the power plug.
Definitely not. openHABian is not a router or anything similar. It’s producing data that needs to be safely and permanently stored which is why you must shutdown it correctly to sync that data.
And you shouldn’t reboot at all. Under normal circumstances there is no need to, openHAB(ian) is designed to run 24/7.
Adding that to the dashboard would just make more people hit the button without a need to (which usually creates more trouble than it resolves).
Even if OH doesn‘t need reboots or shutdowns, the other services and hardware, connected to same Server might require it, especially when one changes settings and configs. In my case after it I have to take Z-stick and SD card out for backup, so I will need to shutdown OH properly.
I’m aware of that, sometimes it’s enough to say “I don’t know” but as you tried to point out that I’m not capable of rebooting properly I was keen to see what your magic solution is.
well, I’ll figure it out self then
(and because it is happening on two independed rpis running zram and 1.5openhabian I hardly believe your’s magically works out of the box)
