I’ve just verified on third fresh instalation from image 1.5 from openhabian github.
when I run openhabian-config for first time after instalation and install zram, overlay is not there.
even process behind looks different, when I’ve run it after updating/upgrading installing recommended packages it actually compiled it on the fly. Which on first run was not the case.
This is the third case, when reboot function is needed. And sorry, this is not always because I want to do this, but because when someone wants to get help on OH forum first question from experts is “Did you try to reboot?” Second question is more weird “Can you show us your startup log? Oh, your Installation runs since XX days? So can you please reboot to see the startup logs to check if nothing strange happens there?”. So rebooting sometimes helps to diagnose problems, right?
Funny is that there is no option in openhabian-config to disable ZRAM. I’m reinstalling Openhabian now to switch this feature off.
Can you open an openhabian Github issue please and upload a log of this (set -x in scripts should do) to show those two instances of the zram install process? If you can pls hotfix /opt/openhabian/functions/zram.bash
as in https://github.com/openhab/openhabian/pull/656 before calling it for the first time.
Merged. Please verify openhabian-config updates itself on first start to contain this fix.
I have a vague idea but need some input to verify.
There is, the line below the ‘activate’ line (6A).
It depends. Which is part of the problem because non-Linux people don’t know/understand the background. But as a rule of thumb it does more damage than good.
I can confirm that another fresh instalation without anything else done in openhabian-config compiled overlay correctly and it is present.
Thanks for fix, it will help a lot of people with struggling.
suggestion:
make zram sync to disk on regular basis via cron. like once per 2-3hours should be just fine to maintain fresh OH folder in case of any powerfailure.
Well if only it was that simple … I even contributed a patch to do that but the original tool’s author insists on that it isn’t safe to sync. He probably has got time-critical use cases in mind that we don’t have in openHABian but who am I to contradict?
I am having issues to clone my SD card via rpi-sync as the cloned card will boot but openhab crashes instantly. So I figuered to deactivate zram and try again.
Using the option in openhabian-config you mentioned I get
[09:48:57] openhabian@openhab:~$ sudo openhabian-config
[sudo] password for openhabian:
2019-08-22_09:49:05_CEST [openHABian] Checking for root privileges... OK
2019-08-22_09:49:05_CEST [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
2019-08-22_09:49:05_CEST [openHABian] openHABian configuration tool version: [master]v1.5-504(a342f21)
2019-08-22_09:49:05_CEST [openHABian] Checking for changes in origin... OK
/opt/openhabian/functions/zram.bash: line 18: /usr/local/share/zram-config/uninstall.sh: Permission denied
2019-08-22_09:49:34_CEST [openHABian] Checking for default openHABian username:password combination... FAILED
2019-08-22_09:49:35_CEST [openHABian] We hope you got what you came for! See you again soon ```
My username:password are the default ones that come with openhabian.
I tried “sudo service zram-config stop” but “sudo fdisk -l” still shows zram
<snip>
Disk /dev/ram14: 4 MiB, 4194304 bytes, 8192 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk /dev/ram15: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/mmcblk0: 7.4 GiB, 7969177600 bytes, 15564800 sectors
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0xebcab588
Device Boot Start End Sectors Size Id Type
/dev/mmcblk0p1 8192 532480 524289 256M c W95 FAT32 (LBA)
/dev/mmcblk0p2 540672 15564799 15024128 7.2G 83 Linux
Disk /dev/sda: 14.7 GiB, 15802040320 bytes, 30863360 sectors
Disk model: SDDR-113
Disklabel type: dos
Disk identifier: 0x267623a1
/dev/sda1 8192 532480 524289 256M c W95 FAT32 (LBA)
/dev/sda2 540672 30863359 30322688 14.5G 83 Linux
Disk /dev/zram1: 400 MiB, 419430400 bytes, 102400 sectors
Units: sectors of 1 * 4096 = 4096 bytes
Sector size (logical/physical): 4096 bytes / 4096 bytes
Disk /dev/zram2: 300 MiB, 314572800 bytes, 76800 sectors
How can I tell zram is actually deactivated?
Thank you!
I don’t know what that has to do with zram.
Either way if you really want to clone the card use Amanda or dd.
/dev/ram is not /dev/zram.
If you get “Permission denied” running as root something’s seriously wrong there.
Eventually you have processes running off a directory that is mounted as zram.
If you want to be on the safe side edit /etc/ztab and reboot.
