[SOLVED] WARNING - latest SNAPSHOT 1276
I am getting these WARNINGs after updating to the latest snapshot 1276
These are all related to rules using the Member of trigger
2018-05-15 07:56:19.892 [WARN ] [pse.smarthome.core.items.GenericItem] - failed notifying listener 'org.eclipse.smarthome.model.rule.runtime.internal.engine.RuleEngineImpl@51c2828' about state update of item EntryDoors: null
	at org.eclipse.smarthome.model.rule.runtime.internal.engine.RuleTriggerManager.internalGetChangeRules(RuleTriggerManager.java:336) [136:org.eclipse.smarthome.model.rule.runtime:0.10.0.201805141751]
	at org.eclipse.smarthome.model.rule.runtime.internal.engine.RuleTriggerManager.internalGetRules(RuleTriggerManager.java:427) [136:org.eclipse.smarthome.model.rule.runtime:0.10.0.201805141751]
	at org.eclipse.smarthome.model.rule.runtime.internal.engine.RuleTriggerManager.getRules(RuleTriggerManager.java:198) [136:org.eclipse.smarthome.model.rule.runtime:0.10.0.201805141751]
	at org.eclipse.smarthome.model.rule.runtime.internal.engine.RuleEngineImpl.stateChanged(RuleEngineImpl.java:202) [136:org.eclipse.smarthome.model.rule.runtime:0.10.0.201805141751]
	at org.eclipse.smarthome.core.items.GenericItem$1.run(GenericItem.java:251) [101:org.eclipse.smarthome.core:0.10.0.201805141751]
Could you please enter an issue at https://github.com/eclipse/smarthome/issues? Thanks!
Done - Issue #5578
I get the same bug with S1276 and I don’t use Member of in my rules.
2018-05-15 13:02:48.716 [WARN ] [pse.smarthome.core.items.GenericItem] - failed notifying listener 'org.eclipse.smarthome.model.rule.runtime.internal.engine.RuleEngineImpl@7328ff43' about state update of item FibBut01_Scene: null
rule:
rule    "Fibaro Button 01 Pushing"
        Item FibBut01_Scene changed
        var     Number dimValue = 0
        switch (FibBut01_Scene.state) {
                case 1.0: {
                        logInfo("FB01", "FB01 1x pushed, set Lights at 0%")
                        dimValue = 0
                case 1.1: {
                        logInfo("FB01", "FB01 1x let go, set Lights at 10%")
                        dimValue = 10
                case 1.2:       {
                        logInfo("FB01", "FB01 1x kept in, set Lights at 50%")
                        dimValue = 50
                case 1.3:       {
                        logInfo("FB01", "FB01 2x pushed, set Lights at 100%")
                        dimValue = 100
                case 1.4:       {
                        logInfo("FB01", "FB01 3x pushed, set Lights at 3%")
                        dimValue = 3
                case 1.5:       {
                        logInfo("FB01", "FB01 4x pushed, set Lights at 2%")
                        dimValue = 2
                case 1.6:       {
                        logInfo("FB01", "FB01 5x pushed, set Lights at 1%")
                        dimValue = 1
                default:        {
                        logInfo("FB01", "FB01 State is: " + FibBut01_Scene.state)
        WDim01_Dim.sendCommand(dimValue)
I will monitor the issue @ github and wait for a new snapshot :slight_smile:
falling back (downgrading S1276) to S1275 for now :slight_smile:
apt-get update
apt-get install openhab2=2.3.0~20180514152051-1
I can confirm, it is not only for “member of” rules - I already have a fix and am just about to also write some test cases to avoid such regressions in future! We will have a new distro by tonight.
no worries. We like Snapshot testing :slight_smile:
No problems, this is what snapshots are for…
Could you try distro #1277 and check whether your problems are solved? To me it looks good so far.
confirmed
bada bing, bada boom… logs are sparky clean again with S1277 :+1:
