I am still trying to get this CT100 thermostat working. I’m obviously missing some core concepts. So, one at a time:
If I edit ct100.items, it generates the following warnings. Can someone point me to what I’m not understanding about ‘n.0’ (presumably a float) vs ‘n’ (presumably in this context a string, or maybe an integer?)
I assume that the ?F in the state change messages simply mean that the little small-circle degree symbol isn’t in the character set being used?
Thanks in advance!
2019-10-21 20:17:36.714 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'ct100.items'
2019-10-21 20:17:37.098 [vent.ItemStateChangedEvent] - HVAC_HeatSetPoint changed from NULL to 70.0 ?F
2019-10-21 20:17:37.126 [vent.ItemStateChangedEvent] - HVAC_Cooling_SetPoint changed from NULL to 78.0 ?F
2019-10-21 20:17:37.179 [vent.ItemStateChangedEvent] - Temperature_HVAC changed from NULL to 70.5 ?F
2019-10-21 20:17:37.212 [vent.ItemStateChangedEvent] - HVAC_Operating_Mode changed from NULL to 1.0
2019-10-21 20:17:37.230 [vent.ItemStateChangedEvent] - HVAC_Operating_State changed from NULL to 0.0
2019-10-21 20:17:37.249 [vent.ItemStateChangedEvent] - HVAC_Fan_Mode changed from NULL to 0.0
2019-10-21 20:17:37.269 [vent.ItemStateChangedEvent] - HVAC_Fan_State changed from NULL to 0.0
2019-10-21 20:17:37.290 [vent.ItemStateChangedEvent] - HVAC_Battery changed from NULL to 98.0
2019-10-21 20:17:37.296 [.ItemChannelLinkAddedEvent] - Link 'HVAC_HeatSetPoint-zwave:device:8601bb4d:node14:thermostat_setpoint_heating' has been added.
2019-10-21 20:17:37.300 [.ItemChannelLinkAddedEvent] - Link 'HVAC_Cooling_SetPoint-zwave:device:8601bb4d:node14:thermostat_setpoint_cooling' has been added.
2019-10-21 20:17:37.304 [.ItemChannelLinkAddedEvent] - Link 'Temperature_HVAC-zwave:device:8601bb4d:node14:sensor_temperature' has been added.
2019-10-21 20:17:37.307 [.ItemChannelLinkAddedEvent] - Link 'Humidity_HVAC-zwave:device:8601bb4d:node14:sensor_relhumidity2' has been added.
2019-10-21 20:17:37.311 [.ItemChannelLinkAddedEvent] - Link 'HVAC_Operating_Mode-zwave:device:8601bb4d:node14:thermostat_mode' has been added.
2019-10-21 20:17:37.315 [.ItemChannelLinkAddedEvent] - Link 'HVAC_Operating_State-zwave:device:8601bb4d:node14:thermostat_state' has been added.
2019-10-21 20:17:37.320 [.ItemChannelLinkAddedEvent] - Link 'HVAC_Fan_Mode-zwave:device:8601bb4d:node14:thermostat_fanmode' has been added.
2019-10-21 20:17:37.323 [.ItemChannelLinkAddedEvent] - Link 'HVAC_Fan_State-zwave:device:8601bb4d:node14:thermostat_fanstate' has been added.
2019-10-21 20:17:37.326 [.ItemChannelLinkAddedEvent] - Link 'HVAC_Battery-zwave:device:8601bb4d:node14:battery-level' has been added.
2019-10-21 20:17:37.482 [WARN ] [rm.AbstractFileTransformationService] - Could not transform '0.0' with the file 'thermostatFanState.map' : Target value not found in map for '0.0'
2019-10-21 20:17:37.499 [WARN ] [rm.AbstractFileTransformationService] - Could not transform '0.0' with the file 'thermostatFanState.map' : Target value not found in map for '0.0'
2019-10-21 20:17:37.485 [WARN ] [rm.AbstractFileTransformationService] - Could not transform '0.0' with the file 'thermostatFanState.map' : Target value not found in map for '0.0'
2019-10-21 20:17:37.517 [WARN ] [rm.AbstractFileTransformationService] - Could not transform '0.0' with the file 'thermostatFanState.map' : Target value not found in map for '0.0'
2019-10-21 20:17:37.507 [WARN ] [rm.AbstractFileTransformationService] - Could not transform '0.0' with the file 'thermostatFanState.map' : Target value not found in map for '0.0'
2019-10-21 20:17:37.601 [WARN ] [rm.AbstractFileTransformationService] - Could not transform '1.0' with the file 'thermostatOpMode.map' : Target value not found in map for '1.0'
2019-10-21 20:17:37.635 [WARN ] [rm.AbstractFileTransformationService] - Could not transform '0.0' with the file 'thermostatFanMode.map' : Target value not found in map for '0.0'
2019-10-21 20:17:37.656 [WARN ] [rm.AbstractFileTransformationService] - Could not transform '1.0' with the file 'thermostatOpMode.map' : Target value not found in map for '1.0'
2019-10-21 20:17:37.662 [WARN ] [rm.AbstractFileTransformationService] - Could not transform '1.0' with the file 'thermostatOpMode.map' : Target value not found in map for '1.0'
2019-10-21 20:17:37.665 [WARN ] [rm.AbstractFileTransformationService] - Could not transform '0.0' with the file 'thermostatOpState.map' : Target value not found in map for '0.0'
2019-10-21 20:17:37.681 [WARN ] [rm.AbstractFileTransformationService] - Could not transform '0.0' with the file 'thermostatFanMode.map' : Target value not found in map for '0.0'
2019-10-21 20:17:37.703 [WARN ] [rm.AbstractFileTransformationService] - Could not transform '1.0' with the file 'thermostatOpMode.map' : Target value not found in map for '1.0'
2019-10-21 20:17:37.703 [WARN ] [rm.AbstractFileTransformationService] - Could not transform '0.0' with the file 'thermostatFanMode.map' : Target value not found in map for '0.0'
2019-10-21 20:17:37.715 [WARN ] [rm.AbstractFileTransformationService] - Could not transform '0.0' with the file 'thermostatOpState.map' : Target value not found in map for '0.0'
2019-10-21 20:17:37.718 [WARN ] [rm.AbstractFileTransformationService] - Could not transform '1.0' with the file 'thermostatOpMode.map' : Target value not found in map for '1.0'
2019-10-21 20:17:37.745 [WARN ] [rm.AbstractFileTransformationService] - Could not transform '0.0' with the file 'thermostatOpState.map' : Target value not found in map for '0.0'
2019-10-21 20:17:37.755 [WARN ] [rm.AbstractFileTransformationService] - Could not transform '0.0' with the file 'thermostatFanMode.map' : Target value not found in map for '0.0'
2019-10-21 20:17:37.782 [WARN ] [rm.AbstractFileTransformationService] - Could not transform '0.0' with the file 'thermostatFanMode.map' : Target value not found in map for '0.0'
2019-10-21 20:17:37.798 [WARN ] [rm.AbstractFileTransformationService] - Could not transform '0.0' with the file 'thermostatOpState.map' : Target value not found in map for '0.0'
2019-10-21 20:17:37.827 [WARN ] [rm.AbstractFileTransformationService] - Could not transform '0.0' with the file 'thermostatOpState.map' : Target value not found in map for '0.0'
2019-10-21 20:17:38.025 [WARN ] [rm.AbstractFileTransformationService] - Could not transform '0.0' with the file 'thermostatFanState.map' : Target value not found in map for '0.0'
2019-10-21 20:17:38.066 [WARN ] [rm.AbstractFileTransformationService] - Could not transform '0.0' with the file 'thermostatFanState.map' : Target value not found in map for '0.0'
2019-10-21 20:17:38.105 [WARN ] [rm.AbstractFileTransformationService] - Could not transform '0.0' with the file 'thermostatFanState.map' : Target value not found in map for '0.0'
2019-10-21 20:17:38.141 [WARN ] [rm.AbstractFileTransformationService] - Could not transform '0.0' with the file 'thermostatFanState.map' : Target value not found in map for '0.0'
2019-10-21 20:17:38.151 [WARN ] [rm.AbstractFileTransformationService] - Could not transform '1.0' with the file 'thermostatOpMode.map' : Target value not found in map for '1.0'
2019-10-21 20:17:38.151 [WARN ] [rm.AbstractFileTransformationService] - Could not transform '0.0' with the file 'thermostatFanState.map' : Target value not found in map for '0.0'
2019-10-21 20:17:38.171 [WARN ] [rm.AbstractFileTransformationService] - Could not transform '0.0' with the file 'thermostatFanMode.map' : Target value not found in map for '0.0'
2019-10-21 20:17:38.171 [WARN ] [rm.AbstractFileTransformationService] - Could not transform '1.0' with the file 'thermostatOpMode.map' : Target value not found in map for '1.0'
2019-10-21 20:17:38.217 [WARN ] [rm.AbstractFileTransformationService] - Could not transform '1.0' with the file 'thermostatOpMode.map' : Target value not found in map for '1.0'
2019-10-21 20:17:38.229 [WARN ] [rm.AbstractFileTransformationService] - Could not transform '1.0' with the file 'thermostatOpMode.map' : Target value not found in map for '1.0'
2019-10-21 20:17:38.229 [WARN ] [rm.AbstractFileTransformationService] - Could not transform '0.0' with the file 'thermostatOpState.map' : Target value not found in map for '0.0'
2019-10-21 20:17:38.232 [WARN ] [rm.AbstractFileTransformationService] - Could not transform '0.0' with the file 'thermostatFanMode.map' : Target value not found in map for '0.0'
2019-10-21 20:17:38.250 [WARN ] [rm.AbstractFileTransformationService] - Could not transform '1.0' with the file 'thermostatOpMode.map' : Target value not found in map for '1.0'
2019-10-21 20:17:38.258 [WARN ] [rm.AbstractFileTransformationService] - Could not transform '0.0' with the file 'thermostatFanMode.map' : Target value not found in map for '0.0'
2019-10-21 20:17:38.263 [WARN ] [rm.AbstractFileTransformationService] - Could not transform '0.0' with the file 'thermostatFanMode.map' : Target value not found in map for '0.0'
2019-10-21 20:17:38.274 [WARN ] [rm.AbstractFileTransformationService] - Could not transform '0.0' with the file 'thermostatOpState.map' : Target value not found in map for '0.0'
2019-10-21 20:17:38.276 [WARN ] [rm.AbstractFileTransformationService] - Could not transform '0.0' with the file 'thermostatFanMode.map' : Target value not found in map for '0.0'
2019-10-21 20:17:38.303 [WARN ] [rm.AbstractFileTransformationService] - Could not transform '0.0' with the file 'thermostatOpState.map' : Target value not found in map for '0.0'
2019-10-21 20:17:38.304 [WARN ] [rm.AbstractFileTransformationService] - Could not transform '0.0' with the file 'thermostatOpState.map' : Target value not found in map for '0.0'
2019-10-21 20:17:38.326 [WARN ] [rm.AbstractFileTransformationService] - Could not transform '0.0' with the file 'thermostatOpState.map' : Target value not found in map for '0.0'
why is it trying to transform a floating ‘0.0’ or ‘1.0’ rather than a string ‘0’ or ‘1’
Here are the relevant files:
/* Thermostat CT100*/
Group gHVAC
Number:Temperature HVAC_HeatSetPoint "Set House Heating [%.0f %unit%]" (gHVAC) {channel="zwave:device:8601bb4d:node14:thermostat_setpoint_heating", autoupdate="false" }
Number:Temperature HVAC_Cooling_SetPoint "Set House Cooling [%.0f %unit%]" (gHVAC) {channel="zwave:device:8601bb4d:node14:thermostat_setpoint_cooling", autoupdate="false" }
Number:Temperature Temperature_HVAC "Temperature [%.1f %unit%]" <temperature> (gHVAC,Temp_Chart) {channel="zwave:device:8601bb4d:node14:sensor_temperature"}
Number Humidity_HVAC "Humidity [%.1f %%]" <humidity> (gHVAC,Hum_Chart) {channel="zwave:device:8601bb4d:node14:sensor_relhumidity2"}
Group gHVACStatus
Number HVAC_Operating_Mode "Tstat Mode [MAP(thermostatOpMode.map):%s]" <flow> (gHVACStatus) {channel="zwave:device:8601bb4d:node14:thermostat_mode" }
Number HVAC_Operating_State "Op State [MAP(thermostatOpState.map):%s]" <flow> (gHVACStatus) {channel="zwave:device:8601bb4d:node14:thermostat_state"}
Number HVAC_Fan_Mode "Fan Mode [MAP(thermostatFanMode.map):%s]" <fan> (gHVACStatus) {channel="zwave:device:8601bb4d:node14:thermostat_fanmode" }
Number HVAC_Fan_State "Fan State [MAP(thermostatFanState.map):%s]" <fan> (gHVACStatus) {channel="zwave:device:8601bb4d:node14:thermostat_fanstate"}
Number HVAC_Battery "Battery State [%d %%]" <battery> (gHVACStatus) {channel="zwave:device:8601bb4d:node14:battery-level"}
I understand (I think) that ‘Number’ casts as a float, but did I misunderstand that the MAP(yada):%s converts to string?
ThermostatOpState.map
0=Idle
1=Heating
2=Cooling
3=Fan Only
4=Pending Heat
5=Pending Cool
6=Vent / Economizer
ThermostatOpMode.map
0=Off
1=Heat
2=Cool
3=Auto
4=Aux Heat
5=Resume
6=Fan Only
7=Furnace
8=Dry Air
9=Moist Air
10=Auto Changeover
11=Heat Econ
12=Cool Econ
13=Away
ThermostatFanState.map
0=Idle
1=Running
2=Running High
ThermostatFanMode.map
0=Auto Low
1=On Low
2=Auto High
3=On High
4=Unknown
5=Unknown
6=Circulate
These were all cribbed from:
This is the sitemap I’m using. Crude, yes, but good enough to learn with:
sitemap mobile label="23 Mobile Display"
Text item=Door_Garage label="Garage Door"
Text item=Presence_Sue_Phone label="Sue's Mobile"
Text item=Door_Garage label="Garage Door" labelcolor=["red"] icon="error" visibility=[Door_Garage=="OPEN"]
Text item=Temperature_HVAC label="Room Temp"
Text item=HVAC_Operating_State label="Operating State"
Selection item=HVAC_Operating_Mode label="Tstat Mode" mappings=[0="OFF", 1="HEAT"]
Setpoint item=HVAC_HeatSetPoint label="Furnace Setpoint" minValue=55 maxValue=80 step=1
Other relevant info:
2019-10-21 21:46:25,289: FireMotD: Info: Action "theme"
############### openhab #####################################################
## Ip = 192.168.22.15
## Release = Raspbian GNU/Linux 10 (buster)
## Kernel = Linux 4.19.75-v7+
## Platform = Raspberry Pi 3 Model B Rev 1.2
## Uptime = 0 day(s). 22:50:52
## CPU Usage = 2.78% avg over 4 cpu(s) (4 core(s) x 1 socket(s))
## CPU Load = 1m: 0.37, 5m: 0.25, 15m: 0.20
## Memory = Free: 0.04GB (4%), Used: 0.91GB (96%), Total: 0.95GB
## Swap = Free: 0.03GB (41%), Used: 0.05GB (59%), Total: 0.09GB
## Root = Free: 24.78GB (89%), Used: 2.99GB (11%), Total: 28.99GB
## Updates = 0 apt updates available.
## Sessions = 0 session(s)
## Processes = 127 running processes of 32768 maximum processes
Welcome to __ _____ ____ _
____ ____ ___ ____ / / / / | / __ )(_)___ _____
/ __ \/ __ \/ _ \/ __ \/ /_/ / /| | / __ / / __ `/ __ \
/ /_/ / /_/ / __/ / / / __ / ___ |/ /_/ / / /_/ / / / /
\____/ .___/\___/_/ /_/_/ /_/_/ |_/_____/_/\__,_/_/ /_/
/_/
openHAB 2.4.0-1 (Release Build)
Looking for a place to get started? Check out 'sudo openhabian-config' and the
documentation at https://www.openhab.org/docs/installation/openhabian.html
The openHAB dashboard can be reached at http://openhab:8080
To interact with openHAB on the command line, execute: 'openhab-cli --help'
[21:46:29] openhabian@openhab:~$ uname -an
Linux openhab 4.19.75-v7+ #1270 SMP Tue Sep 24 18:45:11 BST 2019 armv7l GNU/Linux
and an aeotec z-stick Gen5
