Hello together,
I have the following problem with Weather Binding:
weather.cfg
apikey.ForecastIo=cbf1a8b9c5d966d...
location.home.latitude=...
location.home.longitude=...
location.home.provider=ForecastIo
location.home.language=de
location.home.updateInterval=120
weather.items
Group gWetter "Wetterbericht" <sun_clouds> (Home, DR)
//Aussentemperatur
Number Aussentemperatur "Außentemperatur [%.1f°C]" <temperature> (gWetter) {weather="locationId=home, type=temperature, property=current"}
//Wetterlage
String Wetterlage "Wetterlage [%s]" <sun_clouds> (gWetter) {weather="locationId=home, type=condition,property=commonId"}
//Wind
String Windrichtung "Windrichtung [%s]" <wind> (gWetter) {weather="locationId=home, type=wind, property=direction"}
Number Windgeschwindigkeit "Windgeschwindigkeit [%dkm/h]" <wind> (gWetter) {weather="locationId=home, type=wind, property=speed"}
//Vorhersage für morgen
String Vorhersage_Wetterlage "Morgen [%s]" <sun_clouds> (gWetter) {weather="locationId=home, forecast=1, type=condition, property=commonId"}
//Minimale Temperatur Morgen
Number Vorhersage_Temperatur_Min "Minimale Temperatur Morgen [%.1f°C]" <temperature> (gWetter) {weather="locationId=home, forecast=1, type=temperature, property=min"}
//Maximale Temperatur Morgen
Number Vorhersage_Temperatur_Max "Maximale Temperatur Morgen [%.1f°C]" <temperature> (gWetter) {weather="locationId=home, forecast=1, type=temperature, property=max"}
sitemap
Frame label="Draußen" {
Group item=DR_Garage
Group item=gSonne
Group item=gWetter {
Frame label="Aktuelle Werte" {
Text item=Aussentemperatur label="Aussentemperatur [%.1f°C]" icon="temperature"
Text item=Wetterlage label="Wetterlage [MAP(Wetterlage.map):%s]" icon="sun_clouds"
Text item=Windgeschwindigkeit label="Windgeschwindigkeit [%.2f km/h]" icon="wind"
Text item=Windrichtung label="Windrichtung [MAP(Windrichtung.map):%s]" icon="wind"
} //END Aktuelle Werte
Frame label="Vorhersage" {
Text item=Vorhersage_Wetterlage label="Wetterlage [MAP(Wetterlage.map):%s]" icon="sun_clouds"
Text item=Vorhersage_Temperatur_Min label="Temperatur [mindestens %.1f°C]" icon="temperature"
Text item=Vorhersage_Temperatur_Max label="Temperatur [maximal %.1f°C]" icon="temperature"
In the server log I get this message after the start:
What could be the reason?
Thank you very much!
