everything is working perfect i get all data from pws to my sitemap but only refresehes every 30 minutes as the default value. i need more accurate values at least every 5 minutes
anyone know how is correct syntax for refresh ?
i´m looking at official site and it looks like refresh " minutes" but doesnt work
I checked the source code and from what I can see, you should be seeing the following error in your log file: Parameter ‘refresh’ must be at least 5 minutes.
Can you try again and see what happens when you set it to 5?
