Platform information:
- Hardware: amd64
- OS: Windows 10
- Java Runtime Environment: JDK .1.8
- openHAB version: 2
Issue of the topic: I started by installing openHabian 2.2.0-1 on a Pi3 and used the Enphase Energy binding. On the Pi3 I created 2 files to configure the Enphase binding, these files are located on the Pi3 at:
/etc/openhab2/services/enphaseenergy.cfg
/etc/openhab2/items/enphaseenergy.items
On the Pi3 I was able to successfully retrieve data from Enphase so the setup on the Pi3 is okay.
I want to debug what is being returned by from the Enphase cloud servers to the binding, so I setup Eclipse on a Windows 10 machine using the IDE Setup instructions located here
I added the Enphase Binding in the Run and Debug configuration PlugIn tab, and when I Run or Debug the openHab server I see that the binding is started:
2017-12-31 22:05:38.612 [DEBUG] [o.b.e.i.EnphaseenergyActivator:41 ] - Enphaseenergy binding has been started.
Under Eclipse I tried putting the enphaseenergy.cfg and enphaseenergy.items files under:
Infrastructure >> launch >> home >> etc
But the log does not show that the Enphase Binding is retrieving data. As well when I goto the PaperUI site from the Windows 10 machine I don’t see the Enphase Binding under Add-ons, though on the Pi3 the Enphase binding appears.
How can I get the Enphase Energy binding to appear under PaperUI Add-ons on the Windows Eclipse IDE machine?
Where in the Eclipse IDE do I put the enphaseenergy.cfg & enphaseenergy.items files?
