I have read the wiki and searched in the posts, but I didn’t find a easy example for put a JSON string in a UDP outbound connection
I mixed a lot of solutions, but without success, someone could help me?
in the items file I put:
Switch button
String sendpg7 "[%s]" { udp=">[192.168.0.106:5015:'REGEX(.*)']" }
in the sitemap
Switch item=button label="UpdateUDP" mappings=[ON="Now"]
in the rule
rule "Pg7 UDP publish"
Item button received command
// Build the command string
val StringBuilder cmd = new StringBuilder
cmd.append('{"page":7,"data":"2017-01-13T16:09:00Z"}')
// Issue the command string to the socket
sendpg7.postUpdate(cmd.toString)
If anyone recognizes parts of his code … sorry I read a lot and copied what I thought I had understood
I want to send a JSON {“page”:7,“data”:“2017-01-13T16:09:00Z”} to an wifi (esp8266) display:
with a python script with the same string the display works… decode data and time…
- where is my error?
- in which log I can find an error | confirm if I send a bad|right formatted packet??
thanks Ale
