[Solved] Widget image location
I have a Openhab config running on a Pi 3 (Openhabiam Image)
Downloaded a Panel WIdget from Github, but I need the Images that belong to that widget put in …\conf\html\images\temperaturesensor
On my Pi I can; t find the conf map.
Where do I need to put my images on a Openhabian Pi?
For openhabian the path is etc/openhab2/html
Sovled. Thanks
Please mark the correct answer as the solution (right under the answer is a checkbox for this, only the thread opener gets this checkbox)
And please change original topic to [solved] Widget image location by editing your question.
:slight_smile:
