Adam, @RiotMode , exactly what I needed. Thanks
Later edit Initially everything worked well and then it suddenly stopped. I then added a thing file in my config and it all seemed allright again:
Thing wifiled:wifiled:DC4F228FE9E4 [ ip="192.168.1.118", port=5577, pollingPeriod=3000, protocol="LD741", driver="CLASSIC", fadeDurationInMs=1000, fadeSteps=100 ]
I also added
97=Color wheel
to the preset map file, so it shows when you are using one of the presets or just the standard colorwheel
